OBX Install-96 850R
Old Jan 30, 2014 | 09:51 PM
badonis's Avatar
Question OBX Install-96 850R
Any advice or things I should know or look out for regarding the obx install?
any advice or comments would be greatly appreciated.
Gasket or no gasket? if so what are the dimension for the bolt pattern between the dp and hot side of turbo? should i make my own?(have gasket paper material with metal inside of it-seems to be of quality)
I'm installing a new TCV, OBX Exhaust system, O2 spacer, new silicone hoses and will adjust the waste gate. (hopefully tomorrow) Just installed oem plugs.
heres a pic of my R. Excuse the brightness its taken from a crappy cellphone.
Old Jan 31, 2014 | 05:57 PM
boxpin's Avatar
Old Jan 31, 2014 | 07:33 PM
gdog's Avatar
Boxpin; where'd you get that? Never seen a gasket between turbo hotside and downpipe; stock or otherwise.
There is a metal gasket between the exhaust manifold and turbo but that one is optional; really not necessary. I put one on mine but that's me. IPD has them and probably the dealer. But if you're not pulling the turbo...
Just put obx on my 855T; tooooo loud IMO; esp the drone. As soon as i get the right parts from jegs, it will going to the muffler shop for "surgery"...
badonis: so I assume you're going catless? Do you have any other mods?
Old Feb 2, 2014 | 11:09 AM
Gdog, let us know what muffler you swapped in there.
Old Feb 2, 2014 | 10:49 PM
badonis's Avatar
Boxpin where did you get that I seen it on a different post but could not figure out where to buy it. I installed the Obx system and found no gasket between the turbo and dp
I installed the OBX system damm... it def sounds nicer but a bit loud...and apparently I'm the only one noticing it, others don't seem to mind.
The clamps worry me (they look weak) and will replace them next weekend along with the rubber pieces the exhaust hangs from.
Fitment was OK and I need to bend and shape a heat shield that is to close for comfort.
The TCV and the waste gate adjustment made a huge difference and i feel like I have a proper turbo sports car. the automatic trans shifts very precisely and the car definitely definitely feel more spirited. Very happy about the upgrades.
no other mods except IPD sway bars. I bought the car maybe 6 months ago
Old Feb 3, 2014 | 12:34 AM
gdog's Avatar
The clamps are OK, but the bolts provided with them are cheesy and will break or strip out on you. Go to the hardware or auto parts store and get better ones asap. You used the stock rubber donuts to hang the exhaust from; didn't you? Unless they're rotted they should work fine. And yes, a bit of heat shield bending is necessary.
Your engine should breath much better now; time to add a tune or even bigger turbo, if you're so inclined..
Old Feb 3, 2014 | 12:41 AM
gdog's Avatar
Will do once it's all done...
Following BP's input from here; post #6
Can Anyone Help Me Pick A Muffler For A New Cat Back? - Performance Modifications - Volvospeed Forums
Old Feb 3, 2014 | 08:06 AM
boxpin's Avatar
I happen to find it on the ground at the junk yard. Someone pulled the turbo and left it.
You can get one here: https://ardideas.3dcartstores.com/Tu...K24_p_199.html
gilber33
Intake, Headers and Exhaust
May 21, 2024 11:43 PM
TheTrainwreck
Nov 13, 2014 07:28 PM
afredo
Feb 9, 2014 08:28 AM
850rt5
Dec 6, 2013 05:46 PM
CRC1021
Dec 11, 2010 07:52 AM
