Need help really bad
Old Apr 10, 2008 | 07:48 PM
rex54's Avatar
Default Need help really bad
I am 17 and i just got a 1995 Volvo 850. But I i took it to get a tune up and i was told my transmission range sensor has a circuit malfunction. Do i need to get a new or rebuit tranny? Or do i just replace the sensor? The code is P0705.
Thanks,
Rex
Old Apr 10, 2008 | 08:02 PM
jks2's Avatar
Default RE: Need help really bad
Probably just the sensor. Tech is our resident repair guru. He can probably give you a better answer. Is the transmission shifting OK?
Old Apr 10, 2008 | 08:35 PM
JPN's Avatar
JPN
Welcome to the forum.
Most likely you only need a new PNP sensor or micro switch. With a service manual, tools & a common sense for safety, you can do it yourself.
http://www.fcpgroton.com/category-ex...37/by_year/45/
JPN
Old Apr 10, 2008 | 08:47 PM
rex54's Avatar
Yeah its shifting ok when the senor works but when it malfunctions it wont get out of the last gear. Its a non turbo 850.
Old Apr 11, 2008 | 08:13 AM
JPN's Avatar
JPN
What do you mean by the last gear, the 4th gear (top gear/overdrive)? If so the torque converter lockup solenoid may need replacement.
P0705 is "Gear Position Sensor Signal Incorrect". See attached for troubleshooting. Also hear Moderator Tech's suggestions.
JPN
[IMG]local://upfiles/6892/FAE848EF335F4B3F84536391BBB716CA.jpg[/IMG]
[IMG]local://upfiles/6892/72194DF9E14C4261A21758403EC02F57.jpg[/IMG]
Old Apr 11, 2008 | 02:48 PM
rex54's Avatar
My mistake 4th gear is what i meant.
Old Apr 12, 2008 | 08:43 AM
Yes sounds like a bad PNP switch.
J Telectro
Jul 27, 2011 11:16 PM
swiftjustice44
May 11, 2011 01:08 AM
AnEskimo
Jul 28, 2010 10:36 PM
uenvyboykin
Dec 29, 2008 02:47 AM
kathleen
Apr 7, 2007 08:36 PM
