new 850 owner check in
Old Oct 25, 2005 | 01:57 PM
bus stop's Avatar
Default new 850 owner check in
Hi all,
I just bought a 95 850 turbo wagon with 101K. I have some question about this car.
what is the main different between normal 850 Turbo to T5 or T5R >>>>
1) are they using the same turbo?
2) what is the different on their suspension set up ( shock, spring rate. sway bar size)?
3) different ECU?
4) any different in brake caliper/ rotor size?
5) any different on the boost pressure between them
Also, anyone install an aftermarket boost gauges and where and which vaccum line I should "T" it?
thank you fro your help
Old Oct 26, 2005 | 03:10 AM
robert213's Avatar
Default RE: new 850 owner check in
ORIGINAL: bus stop
Hi all,
3) different ECU?
From what I have read...
1995 850-Turbo is same as 1996 850-Turbo is same as 1997 850-T5.
1995 850-T5R is same as 1996 850-R is same as 1997 850-R.
Turbo is TD04HL-15G in all of these models.
1995 850-T5R and 1996 850-R has heavier suspension than 1995/96 850-Turbo.
1997 850-R suspension is same as 1997 850-T5 with optional HD suspension.
Boost is controlled electronically by ECU. 1995 850-T5R has OBD-I ECU. 1996/97 850-R has OBD-II ECU. These ECU(s) increase boost from standard 9.6 psi to 10.7 psi during wide open throttle for 10 seconds and then return boost back to 9.6 psi.
Again, this info is from what I have read. This info is debatable. I have not confirmed any of it.
vincentmb615
Apr 12, 2015 09:58 AM
97-850Wagen
Aug 13, 2013 07:19 PM
Markmetzger9494
Oct 29, 2012 05:49 AM
shimby
Nov 21, 2008 07:14 PM
95.850.GLT
Sep 15, 2004 09:00 PM
