next week project. how to reduce noise?
Old Jan 20, 2008 | 09:15 PM
vetalbig's Avatar
Default next week project. how to reduce noise?
so it’s been a while since I’ve been thinking about how noisy my car isinside,
i have decided that ican notdeal with it anymore!
Now the question is how to reduce theinterior noise and what to do with all this plastic covers?
the only one thing that i can think about right now is to go and buy some kind of foam and stick it in betweenthe door and a plastic covers!
allideas would be definitely appreciated!
this is my "Twanda"! lol
[IMG]local://upfiles/13496/9DF464FA012347AFB736664C29C49B5A.jpg[/IMG]
[IMG]local://upfiles/13496/07A522644F994E26AF29D92BCC168F95.jpg[/IMG]
[IMG]local://upfiles/13496/3BD99CCA42DF4742805D40C82F44F119.jpg[/IMG]
Old Jan 21, 2008 | 10:29 AM
JPN's Avatar
JPN
Default RE: next week project. how to reduce noise?
Replacing the engine & tranny mounts may reduce noise. The plastic tabs on the dash is known to break away. As for ABS-plastic trim pieces I would believe you can dampen the noise by the method you're thinking of. Is the exhaust pipe intact?
See what other members have to say, they may have better ideas.
JPN
Old Jan 21, 2008 | 04:50 PM
Systek's Avatar
interior noise NOT related to rattling(two parts hitting each other) use Second Skin damping material on all interior metal parts. This requires taking your seats, center console and door panels off. apply vigorously and put back together...
Old Jan 21, 2008 | 04:57 PM
What kind of noises are you hearing?
Wind noise?
Rattles?
Rumbling?
ETC?
Old Jan 21, 2008 | 08:30 PM
vetalbig's Avatar
thanks for your time averybody!
instrument panel was taking apart by me couple of times and all door covers making some bad noise when i catching roadbumps. i work at camp whitch is kindafar away from civilization so i drive it alot on a bad quality road, so trying to getrid of that plastic shaking noise.
any suggest will be appreciated.
Old Jan 21, 2008 | 08:52 PM
I can't really give that many good ideas because I would take everything apart and fix it pretty much properly.
Have fixed many customers dashes while I had it out doing the Evaperator.
Old Jan 21, 2008 | 09:01 PM
vetalbig's Avatar
you right,
i think i will try to be more patience next time when i put it alltogether,
i have been taking my dashaparttoo many times so i've stripped a bunch of screws in it.
Old Jan 22, 2008 | 09:40 AM
Systek's Avatar
ORIGINAL: vetalbig
you right,
that would be your main problem...panels that are securely fastened...
mjones01
Sep 3, 2007 01:16 PM
v70 2.4t
Sep 10, 2006 12:46 AM
snoboarder_mike
Jul 9, 2006 01:29 AM
busser
May 24, 2006 05:19 PM
jendickson
Feb 27, 2006 03:53 PM
