Reduce Engine Performace
Old Sep 3, 2007 | 09:28 AM
mjones01's Avatar
Default Reduce Engine Performace
Hello
I'm new here, I have a 2002 S80....I bagged back into a friends car and the next day my s80 wouldn't start. I jump it off and got it to start but the following morning it wouldn't say anything. I purchased a new battery and installed it then my car started without any issues. I drove my car for about 15 miles and park it, an hour later it wouldn't start again.I have a message reading Reduce Engine Performance. Any one ever had this issues?
Thanks
Old Sep 3, 2007 | 09:31 AM
Default RE: Reduce Engine Performace
The best thing to do now is have the codes pulled from the system.
Old Sep 3, 2007 | 09:41 AM
mjones01's Avatar
OK you're saying take it somewhere to have the code pull from the system?
Old Sep 3, 2007 | 10:06 AM
mjones01's Avatar
Hello Tech master
Do you think this issue could be fuel relay not getting any power. I released some gas from under my hood and my car started then cut off.
Thanks sir
Old Sep 3, 2007 | 11:13 AM
JPN's Avatar
JPN
Default RE: Reduce Engine Performance
Hello Markus,
Welcome to the forum, and sorry about the problem.
Moderator Tech is the top-dog of the forum and you can't go wrong with Tech's advice.
I would try to locate a local AutoZone or other auto parts shops that provide free diagnostic service. It is called OBD-II diagnostic and they hook up a hand-held scanner and retrieve fault codes from the car's on-board computer. If they can retrieve codes, great, but if no fault code appears on their scanner, then you may have to visit the dealer for further diagnosis.
I wish you the best.
JPN
Old Sep 3, 2007 | 11:24 AM
mjones01's Avatar
JPN
I can see that Moderator Tech is the man, I have been reading several post with great answers from him. I'm not able to start my car to drive it to Autozone. I will have to have my car towed somewhere.
Thanks sir
Old Sep 3, 2007 | 01:16 PM
I would try to check the basics now.
Fuel/spark.
sgtII
Dec 15, 2011 10:55 AM
Timboslice22
Oct 17, 2011 11:15 PM
vetalbig
Jan 22, 2008 09:40 AM
snoboarder_mike
Jul 9, 2006 01:29 AM
96Platinum850
Jan 30, 2006 12:06 AM
