No boost from turbo
Old Jun 5, 2012 | 09:53 PM
Kyfirefighter90's Avatar
Default No boost from turbo
Ok, so I was having a problem with my 850 falling on its face under hard acceleration, I took it to have the codes read and it came up with a problem with the wastegate. I pulled the turbo, and checked the wastegate, and it seemed fine, after replacing the turbo I changed the fuel filter. That fixed a lot of the lack of power. The turbo doesn't spool up and I don't feel the neck snapping power I used to. What could be the problem?
Old Jun 5, 2012 | 10:30 PM
Do you have an aftermarket boost gauge?
Are you sure you connected the vacuum lines correctly?
Old Jun 6, 2012 | 02:18 PM
I don't have an aftermarket boost gauge yet, that's later on down the road, apparently when I pulled the turbo, the wastegate hose became disconnected, and the hose on the bottom of the turbo became disconnected, they are just hanging, they are connected to the turbo, but not on the other end? Where do they go?
Old Jun 6, 2012 | 09:10 PM
gilber33's Avatar
Let me google that for you
Old Jun 6, 2012 | 11:24 PM
So where are you at with it now and what was the code it gave you pointing to a wastegate problem ??
Old Jun 9, 2012 | 10:51 PM
I have the vacuum lines hooked back up right, thanks gilber, now it's hard starting when hot, still no boost, could this be a timing issue?
Old Jun 10, 2012 | 07:13 PM
What were the codes you had / have ??
thecheat
Sep 22, 2010 08:48 PM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
mygreenbomb
Feb 29, 2008 06:09 PM
blkwgnt5r
Mar 10, 2005 01:18 PM
