no brake lights
Old Oct 14, 2004 | 11:35 AM
sam850's Avatar
Default no brake lights
in my 97 850
all my brake lights went out at once...its not the bulbs, not the fuse.
my next guess is the switch, what do others think?
if so how do i change out the switch
Old Oct 14, 2004 | 09:27 PM
Default RE: no brake lights
The brake light switch sounds about rite they are known to go.They arent that bad to change out.It will take you abot 30-40 mins if you havent ever done one before.There is and adjustment that can be made to them to try first.Try pushing on the switch with the brake pedal pushed down.You should feel the switch move in towards the brake pedal.Then pull up on the pedal to adjust to proper position.Good luck.
aznyaz
Jan 9, 2015 02:38 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
Scott V
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
