No spark after airbag replacement
Old May 26, 2010 | 09:02 AM
stojakovic's Avatar
Default No spark after airbag replacement - Solved !!!
Recently had an accident while jam in the highway, airbags deployed. Found a set off ebay and replaced them based on instructions from http://volvo850.shutterfly.com/.
While I am trying to activate the system, the car won't start. The starter motor cranks.
After several diagnoses, I found there is no spark. There are power at green wire of starter which means no PNP switch (also starter cranks). I can smell some fuel in the air.
Per trouble shooting instructions in the pdfs, I was directed to "engine performance" section. and now I am lost.
I can confirm the ignition system is good, as I can still drive the car home after accident.
I am start to suspect fuel system, but can the fuel system failure prevent forming sparks?
Old May 26, 2010 | 09:47 PM
fcpgroton's Avatar
Former Sponsor
I bet something with the immobilizer became messed up when you installed the air bag. Something in the steering wheel is not talking to the key so the car will not start.
Old May 28, 2010 | 08:03 AM
stojakovic's Avatar
Had carefully checked the voltage at the ignition discharge coil this morning, about 12v when cranking. Also checked voltage on the coil out from distributor, about 6v to 11v while cranking.
Engine has a good ground.
So the voltage from the discharge is too low or out of my multimeter's reading capability.
Old May 28, 2010 | 09:13 AM
stojakovic's Avatar
The immobilizer will prevent the starter from cranking, right? My starter cranks.
Old May 29, 2010 | 01:14 PM
stojakovic's Avatar
Going to clean the Camshaft position sensor for a try.
Old May 30, 2010 | 09:39 AM
stojakovic's Avatar
Default Solved!!!
Yes, I know I have read something like this. Now it happened to me.
Some birds take my air cleaner as their home... And this prevent enough air going to the engine. Then some sensor may prevent spark.
Here is the truth.
That's sort of funny.
atlantadriver
Apr 26, 2021 08:25 PM
Scott6
Sep 2, 2016 01:21 PM
tobolate
May 25, 2013 01:44 AM
AzNick
May 19, 2012 09:58 PM
tongzilla
Aug 25, 2008 02:24 AM
