Noise from left side temp sensor area
Old Nov 29, 2011 | 04:34 PM
kenm.10's Avatar
Default Noise from left side temp sensor area
Hi all! I'm hearing a noise from the left side temp sensor area - but only when the heater fan speed is on low. Turn the fan off, the noise stops. Sounds like a little rattling fan running behind the grab handle and head liner.
Any ideas?
1996 850 turbo
185,000 kms
Old Nov 29, 2011 | 08:33 PM
There is a fan behind that grab handle. If you look closely you will see a little inch by inch or so grill. if you get that grill off gently you will see the fan that sucks air in for the temp sensor. Use compressed air in a can like for cleaning a computer and blow it out. It might just be dirt and stuff that's making it imbalanced. It could also be that the motor is going out but cleaning is cheap and easy so give it a shot.
Here you go, pictures and everything >>>
http://www.matthewsvolvosite.com/for...hp?f=1&t=32617
Old Nov 30, 2011 | 01:07 AM
kenm.10's Avatar
Thank you! I'll try that....
blackbrick
May 7, 2011 01:46 PM
nicolaselias
Feb 28, 2008 08:23 PM
drum
Aug 13, 2007 10:08 PM
vcolper
Nov 1, 2006 10:20 PM
