Odd Noise when idle
Most likely the serpentine accessory drive belt has been glazed and squealing. Check the belt surface and if glazed, replace the belt with OEM (Continental) , and I would replace the belt tensioner as well.
Also, inspect the timing belt just in case. It should not squeal as the t-belt is cogged, but I would inspect it just in case. One of the pulleys in there may be squealing if the serpentine belt turns out fine.
JPN
JPN
