S70 making odd noise while going slow and/or idling
Old Aug 31, 2009 | 07:35 PM
eagles9989's Avatar
Default S70 making odd noise while going slow and/or idling
until a few weeks ago, my '98 S70 ran beautiful. now whenever i start the car it starts making a weird noise somewhat similar to wet brakes (its in the engine tho).
it makes this noise whenever it is in park or neutral. it also SOMETIMES makes it when in drive (most common while on an incline)
any ideas? i mean my ABS & Tracs off lights recently started coming on too, but it is definitely the engine making this noise
sorry if this doesnt make sense; feel free to ask any q's
Old Aug 31, 2009 | 08:00 PM
Does the brake pedal pulse when it happens?
Also does the car have headlight wipers?
Old Aug 31, 2009 | 08:40 PM
eagles9989's Avatar
it pulses every once in a while like when i take a turn fast or go over railroad tracks (and then those 2 dash lights come on) but i really think that the "shaking/noises" are coming from under the hood and not back by the wheels.
and yes it has headlight wipers (and one of them does act up quite a bit)
i appreciate the help man
Old Aug 31, 2009 | 08:52 PM
I wonder if the headlight motor running is what you are hearing?
Old Aug 31, 2009 | 08:53 PM
Carrots's Avatar
Do you feel any vibration? I'm thinking of pointing you toward an engine mount- the lower right one- sometimes when that one goes out, the oil pan will vibrate against that little loop that sticks out from the engine cradle, and that noise comes and goes depending on what gear it's in, or whether you're on the gas or not.
Old Aug 31, 2009 | 09:09 PM
eagles9989's Avatar
na its definitely not the wiper motor
hmm im definitely going to look into this tomorrow, that sounds exactly like what im experiencing. you can hear the noise a lot more in the car vs outside so the vibrating is definitely a possibility. and yes i can feel it shake sometimes (most likely when im on an incline)
ill keep you posted
Old Aug 31, 2009 | 09:24 PM
Carrots's Avatar
The mount I'm talking about is just to the left of, and below, the harmonic balancer (crankshaft pulley) on the lower right. You'll probably need to take the fender liner loose to see it all the way. Pry VERY GENTLY between the cradle and the oil pan, or place a floor jack with a large block of wood under the engine and lift just enough to take up the weight of the engine- don't lift the car with it, or you could damage the oil pan. Doing either of these things, observe the engine, if it easily moves an inch or 2 up without resistance, the mount is bad. You'll probably see the mount separate from its base, too. Also, if, while at rest, the engine is less than a centimeter or so from that little loop on the cradle, or there's obvious scratch marks on the oil pan from it coming in contact, that's also a sure sign that that mount needs changed.
If the mount is bad, and is soaked in oil,(it usually is) you need to fix the oil leak, or it's going to do it again. A common cause of this is the front 3 bolts on the oil pan (below the balancer.) They pass into an oil passage, and they don't have sealer on them from the factory. There's a technical service bulletin for this, and a search of the forum will get you repair instructions.
Old Sep 3, 2009 | 10:35 AM
eagles9989's Avatar
yup you got that 100% right man. i popped off the right front wheel and i saw those 2 pieces of rubber (spacers) just hanging there by a thread. it looks like these would give out quite often on the passenger side because theyre tiny, but on the driver side it has HUGE spacers cause thats right where the trans is
thanks again!
Old Sep 3, 2009 | 06:49 PM
Glad you found it!
PoroPoika
Nov 1, 2013 06:34 PM
Bluevolvos40
Aug 24, 2013 11:13 AM
JoshVanSlam
Sep 3, 2012 10:36 AM
lukaspanic
Mar 17, 2011 12:32 AM
thekoopa
Jun 11, 2009 07:18 PM
