Odometer busted
Old Mar 5, 2009 | 01:58 PM
Dads850's Avatar
Default Odometer busted
Okay, I know that I need to replace the gear(s) inside my odometer to make it work again. I have a replacement cluster from a wrecked 850 and instead of replacing the gear(s) themselves I am thinking of just swapping out the cluster itself. Thing is, MY car has about 260k miles on it and the replacement cluster reads 136k. Is there a relatively easy way for me to roll the replacement odometer by hand (or drill, whatever) to match my mileage?
Old Mar 5, 2009 | 02:27 PM
bestharry's Avatar
As to my knowledge, the kind of work you will have to do the roll back is same as what needs to be done to replace that gear(s). Atleast with new ones, you will be sure of some life where as the one from wreckers still will hae the possibility of failing anytime.
Old Mar 6, 2009 | 07:54 AM
Psaboic's Avatar
I rolled ours forward by hand. Thing is I only had about 2600 miles to do <grin>
Old Mar 6, 2009 | 05:40 PM
Somthngfrce's Avatar
Take a pencil or whatever you use to roll it with and place it on a drill and roll it that way! Watch your speed though, but this makes it easier
Old Mar 6, 2009 | 07:16 PM
bestharry's Avatar
But the point is that in order to reach this stage where you can roll it manually..you have to dig inside the meter and at that point, isnt it better to replace the gears in your original meter.
Just a suggestion... :P
Old Mar 6, 2009 | 07:17 PM
+1 on that.. If you are going to go thru all that trouble, I would just replace the gear!
Old Mar 7, 2009 | 12:22 PM
Dads850's Avatar
Ok, I'm convinced, I'll just replace the gear....
Old Mar 7, 2009 | 12:26 PM
Here's a play by play on how to do that then..... http://www.matthewsvolvosite.com/odometer_fix.php
ttundraman
Jul 22, 2007 06:52 PM
shwanzee
Jul 17, 2007 01:23 PM
northanger abbey
May 25, 2007 03:59 PM
mnala
Mar 1, 2007 11:48 AM
thatsmrgimp2u
Jul 3, 2005 06:50 PM
