odometer miles correction
Old Jan 18, 2009 | 10:17 AM
trooperone's Avatar
Default odometer miles correction
I recently bought a 94 (non-turbo) 850, and of coursethe odometer was not working. I have purchased the gear to correct the problem with, but I would like to know if anyone knows any way to find out how many exact miles the car really has on it, so when I put the new gear on, I can change the odometer to show the actual, and correct miles. Any help would be appreciated. Thanks!
Old Jan 18, 2009 | 01:34 PM
Default RE: odometer miles correction
Easiest way would be to have the Dealer pull the milage.
Old Jan 18, 2009 | 09:25 PM
JPN's Avatar
JPN
You could also give this a try:
As long as you have the DTC boxes up under the hood ('93-'95).
1. Switch ignition on
2. Connect the fly wire to socket - A7
3. Push button 5 times
4. When LED comes on and stays on, enter code 1-1-1 as follows:
- press the button once when LED is still on
- wait for LED to go out and come on again
- read off response, which will be the last three digits of the odometer miles
5. Repeat steps #3-4, but enter code 1-1-2 (that is, press the button twice on the last step); read off the response, which will be the first three digits of the odometer miles. If you have less than 100,000 miles, the first digit will read as 10 blinks.
This is a post from Matthews Volvo site, courtesy of a poster named MadeinJapan.
http://www.matthewsvolvosite.com/for...pic.php?t=6731
JPN
Old Jan 19, 2009 | 04:11 PM
Ozark Lee's Avatar
I read my actual mileage on my 1994 and then corrected it with a battery drill and a pencil.
http://www.matthewsvolvosite.com/for...a&start=24
...Lee
Old Jan 19, 2009 | 04:14 PM
I just went and saw my buddy at the Dealer because I have heard alot of people have problems trying to pull the milage.
Old Jan 19, 2009 | 06:50 PM
trooperone's Avatar
Thanks all!! I did it by the DTC and it worked great!!! When I had the mechanism apart replacing the gear, I reset it to correct miles and it now works fantastic! I also replaced the bulbs while I had the thing out...so hopefully...no more removing the head! Thanks again for all your help!!!
Old Jan 19, 2009 | 11:09 PM
JPN's Avatar
JPN
Glad the problem is solved!
JPN
Old Jan 20, 2009 | 12:09 AM
nonsense619's Avatar
how about for a 96? is the dealer the only way topull it?
Old Jan 20, 2009 | 08:03 AM
Yes it is. The Dealer will need to pull the milage.
Old Jan 20, 2009 | 08:32 AM
Psaboic's Avatar
Yes, it seems that after 95, it is a lot harder (if not impossible ) to get information out of the ECU without a code reader or dealer software
antonio
Jan 21, 2015 07:04 AM
mark_disfree
Mar 31, 2011 09:46 AM
timer00
May 21, 2009 07:21 PM
88_240_DL
Mar 26, 2005 03:14 PM
Nick Kent
Aug 2, 2004 12:14 AM
