odometer stuck!? what to do?!
Old Mar 25, 2007 | 03:14 AM
Yves666's Avatar
Default odometer stuck!? what to do?!
hey
would like to know what could be wrong with a stucking odometer in an 1994 850 Volvo?!
did u ever heard about thta it just stucked at some point or do I need to consider that someone made it with purpose to get a better price for a used turbo wagon?
how much could it be to repair it and is it possible to do this kind of stuff by DIY?
thanks
yves
Old Mar 25, 2007 | 04:17 AM
JPN's Avatar
JPN
Default RE: odometer stuck!? what to do?!
Greetings from Yokohama, Japan.
850's odometer seems to fail sometimes. The gear teeth seem to have been poorly designed. Refer to the following:
http://www.matthewsvolvosite.com/odometer_fix.php
http://www.google.co.jp/search?hl=ja...dometer&lr=
Should you decide to attack this yourself, you will need to remove the dash top cover, which is held by several Torx screws (be careful with pax-side SRS, make sure to disconnect the battery before proceeding). Also, getting into the inst cluster requires meticulous work & attention to detail.
I hope this helps.
JPN
Old Mar 25, 2007 | 02:29 PM
Psaboic's Avatar
Yep, JPN said it best. I fixed the odometer in my son's 95 850 using the above posted links. Took about 2.5 hours to do it all. While you are in there you might want to replace any burned out instrument lights too.
Old Mar 25, 2007 | 02:35 PM
youngvolvoowner's Avatar
My odometere hasnt worked since I got it its a 94 850, so i guess their infamous for getting stuck, i bought it stuck on 168k, so its possibly higher mileage than that!!
Old Mar 25, 2007 | 09:09 PM
JPN's Avatar
JPN
Hello Youngvolvo,
Make sure to keep track of the timing belt. If it breaks while the engine is running, it will be .
JPN
Old Mar 26, 2007 | 08:17 AM
Volgrrr's Avatar
Your Volvo will record the actual mileage it has travelled.
This mileage is loggedinto thefault diagnostic unit and can be read from there.
It can't recall what the steps are to recover thevehicle mileage from the fault diagnostic unit, but I'm sure the information has already been posted on thisforum somewhere.
Old Mar 26, 2007 | 04:31 PM
ORIGINAL: Volgrrr
Can I get some more information on that? I am really interested and tried googling it with little to no results.
Old Mar 26, 2007 | 05:13 PM
B1mmer's Avatar
http://www.matthewsvolvosite.com/cha...pic.php?t=6731
- AB
Old Mar 27, 2007 | 03:19 AM
RedTurbo850's Avatar
Yves, while you're at it, remove the Service light bulb. It's really annoying.
Old Mar 28, 2007 | 12:06 AM
Excellent, thank you, only one problem what is a fly wire...and where is socket -A7, and what are DTC boxes? Sorry for all the questions but I know jack about cars, but thats why im here!
Old Mar 28, 2007 | 12:56 AM
JPN's Avatar
JPN
Hi Yvo,
"Fly wire" is the wire that is nested in the OBD-I terminal. The OBD-I terminal is situated in front of the ECU box. Open the hood, look to the left and you'll see a black plastic box in front of the coolant reservoir. In front of the ECU box, there is another little box, and that is the OBD-I terminal. Take the lid off, and you'll see two sockets, each marked as "A" and "B". Take the fly wire off of its nest and insert into the hole #7 on the socket A and follow the procedure provided by AB. When you press the button, make sure to press it firmly, as it feels somewhat loose.
Clearing Service Light for OBD-I:
1. Turn the ignition switch to the 2nd detent (ON?).
2. Insert test lead at the OBD-I terminal to socket A7.
3. Press the test button for 4 times. The LED should light and stay on.
4. Press the test button once and release, wait for the LED to light.
5. Press the test button for 5 times and release, wait for the LED to light.
6. Press the test button for once and release.
7. The LED should flash, which indicates the Service Light has been cleared.
8. Start the engine and ensure that the service light is turned off.
I hope this helps.
JPN
Old Mar 28, 2007 | 03:16 PM
Thanks for the reply mate, alywas rely on your posts, but one thing, Maybe I dont have the boxes?!
Heres a picture of under my hood, can you see it? Also, excuse the ms paint job and the circles, pretend they dont exist, i drew those for sometihng else
http://img.photobucket.com/albums/v2...o/DSC03746.jpg
Old Mar 28, 2007 | 04:17 PM
Nevermind I got it 183 thousand miles here Even though the odomoter says 168k, not too bad, I was nervouse to find out what it really was
Thanks for all your help!
PS. Anyone have directions on how to clear the check engine light? Its getting annoyong!, thanks
Old Mar 28, 2007 | 10:16 PM
JPN's Avatar
JPN
Hello mate,
I've attached a pic, but I guess it's now useless that you've already found the actual mileage.
Cheers,
JPN
[IMG]local://upfiles/6892/F80E7748839440F9992CA2A272FA641C.jpg[/IMG]
Old Mar 29, 2007 | 09:38 PM
Ahh thank man! Ill keep this pic for future reference
Old Mar 29, 2007 | 10:02 PM
JPN's Avatar
JPN
Good luck!.
JPN
[IMG]local://upfiles/6892/E10BA8B852014CD290BB85997E66089B.jpg[/IMG]
Old Jun 14, 2007 | 11:24 AM
  #17
floryed's Avatar
Where can I get this gear? Thanks!!
Old Jun 16, 2007 | 02:13 AM
  #18
hyphyTurbo's Avatar
how about checking mileage on obd-II?
Old Jun 16, 2007 | 06:47 AM
  #19
It can usually be done by the Dealers scanner on the 96 and 97 models.
Obelix
Jun 20, 2022 08:40 AM
amotin
Dec 12, 2008 09:13 PM
Yves666
Apr 28, 2007 11:56 PM
88_240_DL
Mar 26, 2005 03:14 PM
Nick Kent
Aug 2, 2004 12:14 AM
