oil leak - compressor side of turbo
Old Oct 27, 2010 | 07:33 PM
twardnw's Avatar
Default oil leak - compressor side of turbo
Any common culprits for a leak on the compressor side? There is not a bunch of excess oil in the intake tract, and the turbo drain is nice and dry/clean.
Old Oct 27, 2010 | 07:43 PM
vetalbig's Avatar
i had mine leaking from camsensor, took sensor out, sealed it up, nice and clean!
Old Oct 31, 2010 | 02:01 PM
twardnw's Avatar
is it an o-ring/rubber type seal, or just use some high quality RTV/Silicone?
Old Oct 31, 2010 | 04:50 PM
twardnw's Avatar
n/m, found it, and luckily the autozone down the street had one in stock. Cleaned up most of the mess of oil, find out in a bit if that solves the issue for me.
Old Oct 31, 2010 | 07:51 PM
twardnw's Avatar
ok, still haven't solved the oil leak. The cam seal was leaking a small bit, so I know that is not contributing anymore with the new seal in there, but I still have a leak somewhere.
Here's a pic of the area where I can see everything soaked in oil. Unfortunately there's so much crap in the way I can't see where the drip is coming from. :\
also, got a clear look at the oil inlet on the turbo today, it is also clean and dry.
Old Oct 31, 2010 | 08:43 PM
ibified's Avatar
what you need to do is clean the crap out of it with brake cleaner and/or degreaser, then go drive it for a few minutes....hard. then pull it back in the garage and the leak will probably be a lot easier to find.
Old Nov 1, 2010 | 04:24 PM
docmot's Avatar
Your oil pattern looks a lot like mine. I traced my oil drip back to the front of the engine, that is within the timing belt cover. I have not had time to look any further but I think the front crank seal is leaking, the oil is coming out the back of the cover and ending up along the turbo when it is not dripping onto the sub frame.
In my case, there is also oil coming from a drain hole between the rear of the engine and the transaxle housing. Hopefully a PCV replacement will reduce some of the excessive pressure and hold off replacing the seals a bit longer.
Old Nov 2, 2010 | 08:43 PM
twardnw's Avatar
I think that my rear main might be leaking, went for a 'spirited' drive around the neighborhood, pulled the car up on the driveway (steep driveway FTL), and immediately had a dollar-bill sized puddle on the concrete. Jacked up the passenger side, and started the car, then crawled underneath. Watching the side of the flywheel (just behind the intermediate drive shaft), I could see bits of oil accumulating. No oil was coming out of the weep hole at the bottom of the bell-housing, but that is likely due to how steep the driveway is, and that the car was jacked up. After seeing this, it makes sense to me that oil is being flung around by the flywheel, dripping onto the spinning driveshaft, and then being further flung around the backside of the engine. Would be a good reason the bottom side of the compressor is covered.
Old Nov 15, 2010 | 10:40 PM
twardnw's Avatar
Well, replaced the rear main seal this last weekend. That was the culprit for sure, inside the bellhousing was a mess.
For anyone considering doing this job, having just completed it, I would pay for a shop to do it, rather than go through that hell again.
James Ira
Sep 23, 2010 08:28 PM
SuspTech
Jan 25, 2009 09:54 AM
tcrossley
Dec 15, 2008 03:42 PM
vetalbig
Oct 22, 2008 07:34 AM
witstaffy
Jul 25, 2005 09:31 PM
