oil leak problem
Old Oct 3, 2008 | 10:21 PM
csigrist's Avatar
Default oil leak problem
I got a 850 with an oil problem dont know if its actually leaking or what. I never notice anything but little drops of oil on the ground, but around the filler cap and the dipstick there is alot of oil. what do I need to do to get this fixed
Old Oct 3, 2008 | 11:09 PM
Ozark Lee's Avatar
Default RE: oil leak problem
Pull the dipstick and see if you have puffs of smoke or positive pressure - Put a balloon over it and see if it tries to inflate. Chances are you need to service the PCV "System" if that is the case. A new oil cap gasket helps with the stuff on the top of the motor but I would be fearful of clogging more pressure in the crankcase by changing the cap gasket without dealing with the underlying problem.
Do it sooner than later - if it getsreal bad it will start blowing oil seals - like the rear main oil seal.
...Lee
Old Oct 4, 2008 | 01:01 AM
Maxbaby's Avatar
+1 ... if you blow that rear main because you didn't deal with the crankcase pressure, you'll be really upset... big money to fix...
Old Oct 4, 2008 | 09:27 AM
Psaboic's Avatar
Sounds like the O-rings on the dipstick and also the seal ring on the filler cap are shot. However, I would DEFINITELY use the methods mentioned above to check to see if the PCV systems is clogged before fixing the O-rings/seals.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
