Oil leak under radiator
Hi I have an 850 turbo and last night all my oil ended up in my driveway. I looked this morning and found a leak underneath the radiator. There seems to be a pan under there with a hole in it. Does anyone have information on this? What the pan is called? Should it have oil in it?
Thank you for any help is appreciated,
Anna
Anna
There should not be a pan under your radiator. You may want to check the oil level to see how much is actually in the motor. If it is low, put some in and see if it drains out. If it doesn't start draining out, start the car and see if you can see any oil coming out then.
Your car should have a oil line that goes to the oil cooler. They do leak and need replacement. I just did one on my daughters S70. Find the leak and post back. It also would not hurt to post pics as well.
Hmmmmmm. You know, there is a tiny pin hole in the bottom of your intercooler right dead center of that oil mess. Its purpose is to drain oil that makes its way through the turbo into the intercooler. Because of the amount of oil I would agree with rspi but if you dont see anything from the lines or oil cooler then I would pull the hoses off between the turbo and intercooler and see if you see a river making its way through them.
kawish1659
1998-2000 model year XC70
11-06-2013 03:36 AM
enigma9011
09-01-2008 08:06 AM
