Oil Separator; service it or replace it?
Old Jun 14, 2009 | 05:31 PM
amazon2's Avatar
Default Oil Separator; service it or replace it?
I'm an old volvo mechanic (in my 60's and know all about the old volvos 122, 140, 240 stop!) I've recently been dragged into the '90s with a '95 850 wagon. I'm pleased thus far and am being sure that everything re preventative maint is up to date. Seeping oil at the usual spots indicates a clogged PCV system and sure enough the flame trap is plugged but I'm unsure of the procedure regarding the oil separator. How big a job is it? It doesn't look easy to get to. What's the best procedure any of you have discovered? Can it just be blown out or must it be removed and cleaned or replaced?
For any of you old Volvo fans out there try googling An Old Volvo song. TD
Old Jun 14, 2009 | 09:30 PM
nonsense619's Avatar
to get to the oil trap the intake manifold needs to be removed.all you are going to be doing is replacing hoses.not a hard job.most tedious part is removing intake manifold and crimping those volvo hoose clamps.also,i would replace it.not expensive,and personally i cant tell if its truly clean or not so reusing is not an option for me at least.
Old Jun 14, 2009 | 09:37 PM
Chebucto's Avatar
I found this site, Im doing mine next weekend and I think this will all I need.
http://www.lakesidedp.com/uploadpics/pcv/
and I also found the entire kit at FCP...got in 4 days..
http://www.fcpgroton.com/
I also have a 95 850 Turbo Wagon.
Forsyth
Nov 6, 2011 03:01 PM
bonecrusher
May 3, 2011 04:30 PM
sam2010
Aug 6, 2010 01:07 PM
volvolove
Mar 23, 2007 11:41 PM
NSF Ed
Feb 27, 2006 09:21 PM
