Window and sunroof problems
Old Jun 13, 2009 | 06:05 PM
dan2286's Avatar
Default Window and sunroof problems
First problem is my driver side window. Something seems loose in the window track and is causing the window to bind when it gets close to being closed. Sometimes I need to push the window up the rest of the way so it is all the way closed. Is there any common problems that would cause this?
Second problem is my sunroof only opening about half way. It just stops like it hit something in the way. I also noticed within the past week that when closed, it is not sitting flush with the roof. I know it was fine when I got it 5 or 6 months ago.
Thanks for the help.
Old Jun 13, 2009 | 07:42 PM
850tony's Avatar
for the window you need a new window regulator (only like $20 shipped on ebay) and also a small plastic wheel for the window.
Old Jun 14, 2009 | 10:23 AM
Maybe something is stuck in the sunroof track. Maybe you can find instructions to remove and re-install it to see of there any anything stuck in the track or if something is broken.
Old Jun 14, 2009 | 07:54 PM
dan2286's Avatar
I tried taking a look at the sun roof today. I really cant see anything wrong, but I do not know what to look for. I took off the glass and the track moved back and forth fine. I put it back on and it still doesn't work right. I also noticed that the thing that slides open with the glass does not want to close all the way. I also can not get the glass adjusted right, it seem like something is bent. Also, I can't really look back where the glass slides under the roof. Can I take off the headliner to get a better look?
Old Jun 14, 2009 | 09:01 PM
850tony's Avatar
yes. if you are to take off the head liners you can see almost the whole thing.
wagon or sedan?
Old Jun 14, 2009 | 09:03 PM
nonsense619's Avatar
most likely a bent track
Old Jun 15, 2009 | 06:26 AM
Default Sunroof Problem
I would bet against the track being bent. Unless something has smashed in the roof like what happened on my 960, I cant imagine how it would get bent.
I would take the motor out. That should be easy. It is likely under the panel just behind the lights near the rear view mirror. Once you have the motor out, the sunroof should be able to slide open and close by hand. Possibly something got into the track or something broke in there.
timmybdaddyof3
1998-2000 model year V70
Aug 14, 2014 06:01 PM
reecesp1eces
Feb 2, 2014 08:44 PM
laynemoore
Nov 17, 2010 07:53 AM
nnamssorxela
Aug 28, 2010 05:26 PM
dugan661
Sep 5, 2008 09:59 PM
