overheating while in traffic
Old Mar 4, 2008 | 02:18 PM
new850driver's Avatar
Default overheating while in traffic
ugh...first let me say, tech i haven't forgotten about looking for that part. i've been slammed with work and haven't even started working on my car yet. i did replace the fuel pump relay yesterday in hopes that it will help with the stalling. now my question is about it overheating...it will only overheat if i'm sitting still in traffic for a long period..it has boiled over once and i'm wondering if i busted a head gasket or what...the heater core is busted, and the thermostat might be bad i'm buying a new therm. tonight, i just wanted to get some opinions on what you all might think be happening.
I drive it to and from work daily and it doesn't overheat. Just if I'm stationary for a long time
Old Mar 4, 2008 | 03:34 PM
Ozark Lee's Avatar
Default RE: overheating while in traffic
Does you radiator fan come on? A good way to test it is to turn on the air conditioner - the fan should come on immediately when the A/C is on. The fan relay seems to be a high failure rate item on 850s and it will lead to the overheating under the circumstances you describe.
...Lee
Old Mar 4, 2008 | 03:36 PM
RedTurbo850's Avatar
Stuck thermostat?
Old Mar 4, 2008 | 04:14 PM
Maxbaby's Avatar
If you're saying that the heater core is busted, then that will affect coolant flow depending on what you mean by busted. What exactly is busted about it?Is it plugged up? Is it leaking? Has it been bypassed? Lee's test of the fan is an easy one to do, so figure that one out right away, and then post back, and clarify what you mean by the heater core is busted. Thermostat is cheap and easy to fix, so go ahead and do it, so that you know it's been done (don't forget the new rubber gasket as well).
Old Mar 4, 2008 | 06:25 PM
Try the new thermostat and see what happens.
Forget about the relay I ended up finding one. Thanks anyway.
Old Mar 8, 2008 | 12:53 PM
well i'm not exactly sure about the heatercore. i thought it was leaking because the floors are wet but, the coolant level in the reservoir is always the same. maybe it has been bypassed. how can i tell. the fan is working. i was going to change thermostat today but it's windy and snowing...it was like 68 yesterday i'm confused.
Old Mar 12, 2008 | 12:47 PM
just an addition if i can ask, I hate asking so many questions but this car i bought was really treated bad and is steadily falling apart. I still have not had a chance to change the thermostat because i dont have a jack to lift the car and drain it. Today i noticed the low coolant light was on but the resevoir is full as to the fan i thought was coming on i might have been wrong when i flip the a/c i hear a weird clicking noise that is coming every 30 sec or so from over by where the timing belt area is...could this be a water pump problem?
Old Mar 12, 2008 | 06:44 PM
JPN's Avatar
JPN
The clicking you hear is most likely the A/C compressor cycling due to low R134a or retiring/faulty pressure switch; a common problem to the 850.
You do not have to drain the coolant completely to replace the thermostat; just drain enough to avoid a mess. You do not have to lift the car; just turn the plastic drain **** CCW and don't forget to place a container to catch draining coolant. A clear plastic tube found at local hardware store is helpful when draining the coolant to avoid mess.
When the engine is stone-cold (overnight is ideal), open the coolant expansion tank cap and see & smell for fuel. If you smell a hint of fuel or see oily appearance in the expansion reservoir, the head gasket may be shot. Also, do you smell coolant in the exhaust gas, or does it have white colour even after the engine has reached the normal operating temp?
Lastly, is your expansion tank cap grey? The original grey cap seems to have had problem so some people have replaced it with revised green cap.
JPN
Old Mar 12, 2008 | 07:39 PM
skeller's Avatar
ORIGINAL: JPN
JPN
JPN is right. The clicking is likely to come from the A/C compressor. Try to answer his questions and give us an update on what you found out.
_____________________________
Keeping auto body parts in perfect shape isn't easy.
Old Mar 12, 2008 | 07:44 PM
oh man, that's what i am afraid of. I just bet that the head gasket is blown. Thank you JPN. I will tell you in the morning if it smells like gasoline. I might not even have to worry about the drain ****, I took the cap off the reservoir while the car was running and it just starte pouring out the top. Thank you so much for your help so far. I wish that I would've found this site before I bought this nightmare.[>:]
Old Mar 13, 2008 | 08:37 AM
okay so here's the update. I have the green cap on my resevoir. I didn't smell any fuel in the resevoir. It just smelled like coolant. i think the exaust possibly has a little smell of coolant, but no white smoke.
Old Mar 14, 2008 | 03:56 AM
jonnyboyca's Avatar
did you change the thermostat yet? you'd be surprised how just replacing that can fix many overheating problems...
~jon
jayistall
Apr 20, 2021 04:30 AM
wgsa13
Nov 22, 2019 01:19 AM
fixedgearhead
Aug 26, 2013 03:46 PM
dlk1
Apr 21, 2007 06:46 AM
dcjcdc
Feb 10, 2007 01:37 AM
