P0130, P0137 - Correct parts?
Old Oct 1, 2018 | 06:13 PM
katie13711's Avatar
Default P0130, P0137 - Correct parts?
I know these codes are in regard to the oxygen sensors. Most people have recommended replacing both the front and rear at the same time. Could someone confirm these are the correct parts? One says upstream, one says downstream.
https://www.fcpeuro.com/products/vol...-15097#reviews
https://www.fcpeuro.com/products/vol...0-v70-15062#qa
I have a 1996 850 Non-Turbo
Thanks,
Katie
Old Oct 1, 2018 | 07:06 PM
860ARE's Avatar
If ones upstream and ones downstream your good. I recomend borrowing a 02 sensor wrench from auto parts store. Run car for a minute to heat them up the. Carefully take them out.
Old Oct 3, 2018 | 02:46 PM
I would do some checking before buying both O2 sensors. The P0130 is saying the ECU is not getting a signal from the front sensor. Could be the sensor, could be wiring so look around. The P0137 is saying there's too much oxygen in the exhaust. Seems to reason that if the front sensor's not reporting in, the mixture is off and the rear sensor goes out of range. My bet is fix the cause of the front sensor issues and the rear sensor code will go away as well.
Newport_j
May 8, 2019 02:48 PM
Krle
Apr 1, 2010 03:33 PM
Quincy56
Nov 20, 2008 10:39 PM
OK_v70_5spd
Dec 15, 2007 10:33 AM
vector1701
Oct 11, 2007 07:46 AM
