P0172 slight miss and no power!! Help!
Old Apr 5, 2013 | 03:21 PM
mal81394's Avatar
Default P0172 slight miss and no power!! Help!
Just replaced whole exhaust system oxy sensors, full tuneup plugs wires rotor cap everything still got a miss and low power. haven't replaced the cool yet and runs the same maf plugged in or not it is a newer maf. New car manifold replaced a lot and very frustrated. Any volvo genius have an idea? We are lost and it is a daily driver. Thanks guys
Old Apr 5, 2013 | 11:01 PM
mal81394's Avatar
Default power
anything?
Old Apr 6, 2013 | 03:53 AM
Do you have a check engine light on ??
Can you try to write so we can understand what it is you are saying ??
Did you replace the whole exhaust system or both the O2 sensors ??
If you are talking about the ignition coil it isn't going to give you a "miss". Usually a miss is a cylinder or two not firing or not firing properly.
If the coils a problem it will be hard to start or lack of higher RPM power on all cylinders but not a "miss" feeling.
Have you thought about doing a compression test to see if you might have a weak cylinder from a mechanical problem and not ignition ??
Might also be one fuel injector leaking too much or plugged and squirting too little.
Try to read your post before you post and maybe after you post to see if it's making sense and if your spelling is correct. If you can't take the time to make the question make sense why should anyone take the time to answer ??
Try reading these:
http://www.matthewsvolvosite.com/for...pic.php?t=6283
http://www.matthewsvolvosite.com/for...ic.php?t=49113
https://volvoforums.com/forum/volvo-...ank-1-a-54611/
https://volvoforums.com/forum/volvo-...t-maybe-17628/
Old Apr 6, 2013 | 08:22 AM
mal81394's Avatar
Default po172
sorry guys just frustrated so I typed badly. I replaced the whole exhaust system and the oxygen sensors. and yes i haven't replaced the coil yet. I also have not replaced the fuel presssure regulator yet. Again sorry guys and hope this helps.
Old Apr 6, 2013 | 08:24 AM
mal81394's Avatar
Default po172
no check engine light but code po172.
Old Apr 6, 2013 | 11:42 AM
mal81394's Avatar
Gained about 5mph with the vacuum line from the intake to the flame trap blocked if that relates to anything. Maybe fuel pressure regulator?
Old Apr 6, 2013 | 11:54 AM
http://atthetipwebs.com/technologyin...ssion_test.htm
Old Apr 6, 2013 | 12:00 PM
mal81394's Avatar
Thanks ill give that a try
Old Apr 6, 2013 | 12:32 PM
MattyXXL's Avatar
Real quick what o2 sensors are you using>??
Old Apr 6, 2013 | 01:27 PM
mal81394's Avatar
Oem Bosch sensors. I heard others caused problems. Anyone ever experience a fuel pump or fuel controller causing these symptoms? Gonna check compression and fuel pressure tomorrow
Old Apr 7, 2013 | 10:16 PM
mal81394's Avatar
Default Figured it out!!!!
Well guys turns out when I did my oil seal replacement I messed up the timing. The diagram I had looked at was not for my car. It seems that on some of them the timing marks are a little different. Anyway, I finally got the timing together and the car runs like a top!!!!! Thanks to everyone for your suggestions. BTW I did a compression test and got 210 on all cylinders and fuel pressure test came out at 40 so everything checks out great now!!! Be careful if you mess with the timing as I did. Make sure you are lining the correct marks up for you year car, mine seemed to be different.
pappabear1973
1998-2000 model year V70
Mar 9, 2015 12:52 PM
gforce
Mar 2, 2014 03:41 PM
BavarianFanatic
Jul 25, 2012 01:25 PM
markerjim
Jul 19, 2010 12:45 PM
Svtfiveoh
Aug 21, 2008 07:46 PM
