P0440
Old 02-25-2008 | 08:00 PM
onmidnighteyes's Avatar
Default P0440
So my friend scanned my 850 and the P0440 code came up which is the Evaporative Emissions failure code. Has this ever happened with anyone else? If so what was the solution and could I possibly get pictures of where everything would be located? I already did the gas cap check and we cleared the check engine light and it hasn't come back on since. I'll feel pretty stupid if that's all it was, lol.
Old 02-25-2008 | 08:09 PM
Maxbaby's Avatar
Default RE: P0440
Always start with year and mileage of your car... helps me anyways... I'm used to seeing a 3 digit trouble code along with which port it had been read from. I don't recognize the "P0440" code myself. Having said that, if it's with the PCV system, I'd reset the system and drive for a week or two and then re-read the codes to see if it comes back. I am saying this because you are talking only of a single code that you have read, and am assuming you aren't having any sort of a driveability problem.
Old 02-25-2008 | 08:35 PM
Ozark Lee's Avatar
Default RE: P0440
It is an EVAP malfunction code. Ususally it comes back to the purge valve. Make sure your gas cap is tight and reset the code before you do anything.
...Lee
Old 02-25-2008 | 10:21 PM
JPN's Avatar
JPN
Default RE: P0440
See attached for possible cause. OBD-I is available only for '93-'95 models.
I hope this is of some use.
JPN
[IMG]local://upfiles/6892/C0FBFCF5394F4FD9A672D316EC04B50A.jpg[/IMG]
[IMG]local://upfiles/6892/5B14B67AB1CA498FBF16F8FE50BA8E0A.jpg[/IMG]
[IMG]local://upfiles/6892/5605BF4D7861440FA04A337A4E38653E.jpg[/IMG]
[IMG]local://upfiles/6892/50D1E7F2A9024A03BE66EB5D4EB75DC7.jpg[/IMG]
Old 02-26-2008 | 09:33 AM
Psaboic's Avatar
Default RE: P0440
It sounds like it was the gas cap. I would see about changing the seal on the cap sometime soon.....just in case
Old 02-26-2008 | 06:23 PM
Default RE: P0440
We reset the codes and the Check Engine light still hasn't come back on. I'll drive it for a few more weeks plus put gas in it see if it comes back on. Also, would the PCV valve have anything to do with coolant leaking?
Default RE: P0440
Oh also, my car's a 1996 R so it has the OBD II port not OBD I but thanks anyways for that JPN.
Old 02-26-2008 | 07:05 PM
Ozark Lee's Avatar
Default RE: P0440
You don't have a PCV valve per se. You havea PCV system. The Volvo engineers worked overtime to make a very simple concept insanely complex.
The short answer to your original question is no. The PCV and a coolant leak are not at all related.
...Lee
That is a good one it made me laugh!!!
Good to know that the code hasn'T returned.
JPN
97-850Wagen
02-08-2019 11:12 PM
Christian Rosario
07-22-2013 09:30 PM
esmith64
04-04-2012 07:24 AM
ryanadolfson
10-11-2010 01:14 AM
Zimbo
05-15-2008 08:40 PM
