P80 SMF/DMF flywheel clutch pressure plate weight
Old Jun 25, 2016 | 09:34 AM
tryingbe's Avatar
Default P80 SMF/DMF flywheel clutch pressure plate weight
Since I am doing a dual mass flywheel (DMF) to single mass flywheel (SMF) conversion, I thought I'd share what I found about the weights of the clutch parts. Weights are going to be a little off due to wear and machining.
98 DMF setup (well used, disc worn to the rivets)
95 SMF setup (used/machined flywheel, new clutch/plate)
Spec SMF clutch setup (lightly used)
R SMF clutch and DMF clutch disc have the same diameter, but the DMF have more friction material
Old Jun 26, 2016 | 02:56 AM
boxpin's Avatar
Are you installing the 6 puck disk?
Old Jun 26, 2016 | 07:33 AM
tryingbe's Avatar
Not until my 6 months old R clutch wears out.
JungleBurger
Mar 4, 2016 08:29 AM
hpanc
Nov 29, 2014 07:19 AM
LOVEvolvos
Feb 21, 2013 11:17 PM
silly2bme
Apr 27, 2008 11:21 AM
iamnickcarter
Nov 3, 2007 03:13 AM
