Passenger door won't open.
Old Apr 8, 2016 | 08:28 PM
rcvolvo's Avatar
Default Passenger door won't open.
Ok today out of the blue, my wife tries to get out of the car and....nothing. Remote locks work auto lock works but I can't open the door from the inside, out side is fine. Does this mean after 7 years of marriage I have to open her door every time as if we were dating again? (kidding) Where do I start?
Old Apr 10, 2016 | 11:00 AM
Are you talking front door or rear? If its the rear, open the door from the outside - there's a metal switch on the door above the latch (ie in the jamb) that's the child safety lock. If the problem is the front, you probably have an actuator rod from the inside handle that has come off and you'd need to remove the door card to check it out and fix.
Old Apr 10, 2016 | 01:26 PM
rcvolvo's Avatar
Yes it was the front door. I did pull the door panel off and found the metal arm that connects the door handle release to the door latch. It was secured with a plastic grommet bushing that was now crumbled apart. I drilled 3 small holes on the lower metal door latch end around the hole and replaced the arm and wired it in. There is not any movement where it is wired so fatigue wont be an issue. It simply wont pop back out...Thanks
karutunian
Mar 27, 2021 05:44 PM
discodave
Jan 18, 2013 03:46 PM
akc
Sep 26, 2010 08:01 AM
bucho1978
Oct 30, 2008 11:40 AM
ss~zoso~ss
Mar 3, 2007 01:25 AM
