Passenger Side Airbag Cover Peeling
Old Feb 20, 2012 | 09:22 AM
x-angel's Avatar
Default Passenger Side Airbag Cover Peeling
Anyone have any suggestions for a fix for this?
Just in case int he future - the link to this picture is broken - the cover over the passenger side air bag is peeling and sticking up. Looking for a fix.
Thanks in Advance!
Old Feb 20, 2012 | 11:20 AM
daver80's Avatar
Default peely
x- mine was peeling (not nearly as bad as that), I removed the cover, glued the cover back together and re installed it.
Unhook battery, unhook airbag, take dash top off, take airbag out, take airbag cover off. I used gorrilla glue to stick the cover down, but the repair looks kinda sloppy. I found a correct color airbag top cover at my local u pull it yard, bought it for $4. It needs only minor gluing, gonna replace it soon. I never found a source for a new top cover. Dave
Old Feb 20, 2012 | 11:45 AM
nitrosport's Avatar
mines go the same issue.
I was thinking gorilla glue, but I was just gonna put the glue where needed and then use some books to hold it down while glue dries. I wasnt gonna remove the dash ect.
Old Feb 20, 2012 | 02:59 PM
snagbranch's Avatar
that looks nasty - i hope mine never does that!!
Old Feb 20, 2012 | 03:50 PM
daver80's Avatar
Default top cover
I thought if I didnt take the cover off I'd end up spoogin glue all over the dash. And that gorrilla glue foams you know, a little goes a long way, dont over do it! Taking the dash top off isnt really a big deal plus you can change any burned out instrument cluster bulbs (I had three) D
Old Feb 20, 2012 | 05:05 PM
x-angel's Avatar
Keep in mind that we are in south west texas, so the heat does a number. But what is funny is that the passenger side airbag cover is the ONLY damage done to the dash. All other cars I have owned have had cracked dashes by now.
okay.. so am I to assume that all of you "gorilla gluers" out there place the glue on the outer part of the dash?
I am sure that the foaming action of GG didn't look that pretty.
Old Feb 20, 2012 | 10:05 PM
Where are the instructions for removing the top of the dash?
Rustynuts
Jan 7, 2016 10:01 PM
Newport_j
Jan 7, 2014 09:20 AM
Newport_j
Dec 17, 2013 07:58 PM
Barnacle Bill
2001-2013 model year XC70
Sep 7, 2013 02:53 PM
tobolate
May 16, 2010 11:29 PM
