PCV system replacement / Oil air separator
Hi guys, how are you doing?
I want to aquire an 850 T5 wagon. I have search a lot about the car and already went to check some cars to buy but what is causing me headeach is the PCV system. i already know all the issues about the PCV, how to check if it's going bad and the step to replace it.
i've been investigating quite a bit regarding the Oil/air separators and how they work, i saw that is implemented in other cars with PCV and there are quite a few that are really good.
So here is my question: Did someone do this change or know about doing this change in the 850 T5? I've been searching everywhere but i couldn't find any 850 T5 with this modification.
Any advice, knowledge, tips or whatever is accepted.
If the PCV system is clogged - just put the factory parts back in. If you use quality oil and change it every 5000 miles - the PCV system will stay clean longer than the car will be alive. Save your money for other things that are going to break on the car.
