PCV System
Old Jul 1, 2013 | 04:31 PM
majorcode's Avatar
Default PCV System
Hi,
My Volvo s80 1999 163000 KM need to check or change PCV, but I am not willing to give to the any mechanic to replace because so far its going good. But yes there is a smoke coming out frm dip stick and I am sure my PCV system is clogged or need replacement.
My Q is, since PCV is just take the gases from engine and put it back ...why not if I keep the Oil dip stick out to get the gases out from there, does it help ???? or any other ideas so that I do not need to do the heavy job of PCV replacement.
Cheers!
Old Jul 1, 2013 | 05:58 PM
quietlymknnoise's Avatar
The pressure will blow the seals out over time.
Old Jul 2, 2013 | 12:00 AM
majorcode's Avatar
You are right quietlymknoise and I am afraid of it. But your comment is not the solution
Old Jun 22, 2014 | 02:00 PM
divinedavis's Avatar
Change the oil catch tank. I had the same problem
MikeySq
Aug 10, 2021 09:52 AM
xjflexer
Jun 16, 2012 11:43 AM
gman47
Mar 4, 2006 06:36 PM
ludeless
Jan 18, 2006 01:01 AM
