PO172
Old Dec 16, 2008 | 10:17 AM
jvrba1's Avatar
Default PO172
My 1997 850 non-turbo keeps coming back with a check engine light.
the code I read from my scanner is PO172- Fuel too rich.
I've looked at several of the other posts with this error code and it looks to be one of several problems:
Vacuum lose.
o2 sensor bad
MAP snesor bad
Can anyone narrow this one down?
I've found a leak on my purge canister vacuum line and have replaced it but the code still comes back.
Is there a step by step process I should go through?
Thanks for any help....
Old Dec 16, 2008 | 12:34 PM
Default RE: PO172
Any other vacuum leaks?
Old Dec 17, 2008 | 07:35 AM
Psaboic's Avatar
Default RE: PO172
Most probable cause I would think would be the O2 sensor. When was the last time it was tuned up, especially the air filter changed?
Old Dec 18, 2008 | 09:32 AM
JPN's Avatar
JPN
Default RE: PO172
My 1st & 2nd replieson the following post may help some:
https://volvoforums.com/m_48928/tm.htm
JPN
Old Dec 21, 2008 | 11:19 AM
jvrba1's Avatar
Default RE: PO172
Not sure about any other vacuum leaks.
How do
I go about testing for leaks?
Old Dec 21, 2008 | 11:20 AM
jvrba1's Avatar
Default RE: PO172
Just changed the air filter...less then a month ago.
Old Dec 21, 2008 | 11:24 AM
jvrba1's Avatar
Default RE: PO172
tuned up the volvo this summer:
rotor
distr. cap
wires
spark plugs
air filter a month ago
found a vacuum leak on the evap...repaired.
Old Dec 21, 2008 | 02:28 PM
Default RE: PO172
With the car running spray around the vacuum lines and if the idle changes there is a leak.
Old Jan 16, 2011 | 08:42 AM
jaltoveros's Avatar
i got same code and change the the mass air flow sensor bought at ebay for $ 65.00.
got rid of the cel but does not improve fuel consumption. I also changed the air filter.
any suggestions? can we use 87 octane? i bought this used volvo just last month.
We got 18 miles per gallon.
miwachiru123
Mar 7, 2016 01:13 PM
Ratman667
Aug 13, 2011 06:52 AM
jvrba1
Dec 16, 2008 12:17 PM
randy
Nov 26, 2007 12:08 PM
akbar
Feb 20, 2006 10:14 PM
