2005 S40 T5 po172 and p0089
Old Sep 15, 2010 | 10:54 AM
Ratman667's Avatar
Default 2005 S40 T5 po172 and p0089
This is my first post and I will start by saying, I know nothing of Volvos. This is for a friend of mine. She will be leaving tonight, headed for Texas. She didn't ask me to look at her car until yesterday afternoon.
I have access to a Solus and Mitchell, but I have to use the Global OBD-II to pull codes, since the Solus doesn't have a Volvo specific menu. There were two codes present:
P0089 Fuel Pressure Regulator 1 Performance
P0172 System too Rich (Bank 1)
Now, from past experience, I know that the P0172 can be caused by a faulty FPR, fuel pump and on occasion a bad vapor canister.
I have searched this forum since last night and cannot find anything pertaining to these two codes at the same time. If I knew what the specs for the fuel pressure is supposed to be, I could test is and better diagnose the problem instead of just throwing parts at it.
I understand these cars frequently have issues with faulty FPRs and if anyone knows of another way to test it, I would greatly appreciate it.
There is also a whining noise from under the back seat, which may be the fuel pump, but again, I am all ears.
I appreciate any input.
Old Jul 29, 2011 | 09:57 AM
DavidB's Avatar
Did you ever get this resolved? I'm having the same combination of symptoms with my 2005 S40.
Old Jul 30, 2011 | 07:13 AM
Hudini's Avatar
Have you checked your fuel pressure?
Old Jul 30, 2011 | 03:39 PM
DavidB's Avatar
That seems like the thing to do but I don't have anything to measure that with.
Old Jul 31, 2011 | 06:34 AM
Hudini's Avatar
Harbor Freight sells a cheap one for about $20.
Fuel Pressure Tester & Fuel Injection Pump Tester
Old Jul 31, 2011 | 07:22 AM
DavidB's Avatar
Thanks, Hudini
Old Aug 12, 2011 | 03:27 PM
DavidB's Avatar
Hudini, a friend of a friend of a friend had one and tested my fuel pressure. It was reading only 9psi. I've replace the pressure sensor and that seems to have done the trick. thanks for pointing me in the right direction.
Old Aug 13, 2011 | 06:52 AM
Hudini's Avatar
Good to hear you fixed it.
miwachiru123
Mar 7, 2016 01:13 PM
apexnut
Feb 2, 2010 08:42 AM
jvrba1
Dec 16, 2008 12:17 PM
randy
Nov 26, 2007 12:08 PM
akbar
Feb 20, 2006 10:14 PM
