Popping noise from Front when breaking
Hey guys...
I've been getting some popping noises when I brake that sound like they're coming from the front of the car...more towards the RH side. It seems to be related to the suspension as it normally does this as the front end of the car moves downward during a breaking event. There is only 1 single pop.
I had noticed the same type of noise from my LH side which i fixed by tightening the bolt connecting the endlink to the strut. I did the same to the bolt on the RH side, but the popping still happens. The endlink itself looks fine...the boot is in good shape.
I'm gonna put it up on the hoist today...any idea what other things i could check while it's up there? Engine mounts... subframe mounts? any thoughtS?
Thanks!
Thanks!
RE: Popping noise from Front when breaking
well, i found that it was the RH endlink where it connects w/ the swaybar. That nut was totally loose and there was a lot of play. So i tigntened it back down to 40 Nm and did the other 3 end link bolts on both sides. It sounded fine when i drove it until about a mile later when the noise came back. I haven't looked at it again to see if the bolt is loose.
What do you look for on an endlink to tell if it's bad?
I don't think it's the break pads as it seems to be related to the position or compression on the suspension system. I can get it to make the noise sometimes by bouncing the front end up/down manually.
I'm still getting that popping noise when breaking. It's a single pop which sounds to be coming from the RH side. I replaced my end links yesterday which made the noise a bit quieter, but it's still there.
I thought that it was attributed to the front end suspension when it's compressed (as the front end dips during breaking), but when the car is parked i can't get the noise to happen when bouncing the front end up/down.
Next i tried pushing it back and forth without the parking break engaged. This is the only way i could get the noise to happen without driving it. I'm now thinking that it might be an engine mount or something, but really have no idea how to verrify this.
I also noticed when doing this the engine rocks back & forth a pretty good amount....prolly a good inch or so. Is this normal?
Any other ideas on what may be making the popping noise?
The upper torque mount is fine...replaced it w/ the IPD one about 5k ago.
However when i was rocking it i did notice the that torque mount frame moves back and forth. Looks like the rubber bushing where it attaches to the firewall allows it to move. Should this be stiff and not allow movement?
The noise was coming from a different place though...i'm kinda thinking now that it may be the Front engine mount on the RH side...connects the subframe to the engine i think. I haven't looked at it yet. What's a good way to access it?
