rear popping noise
Old Dec 23, 2009 | 02:44 AM
gordon368's Avatar
Default rear popping noise
Im getting random rear popping noise, more so when I bank a rear turn, feels like on the passenger rear seat directly under it, it makes a popping noise.
What and how should I go about examing whats wrong?
Thanks
Old Dec 24, 2009 | 03:42 PM
Check the sway bar link first. If that is good the shock might be bad.
Old Dec 24, 2009 | 09:21 PM
gordon368's Avatar
will my sway bar link look like this if its bad?
http://www.wikihow.com/Change-a-Sway-Bar-Link
and just recently about 5 months ago they replaced a front o2 sensor, and the CEL light is on same issue p1152 which I see on here is the o2 sensor. Now from what I hear, That the catalytic converter must be undone to access the o2 sensor? Im assuming there is a clamp with screws holding it in, and as soon as thats undone then I will have access to the o2 sensor?
Do I need a special jack for doing this or is the one supplied with the car good enough?
Is there a special tool I need to do this job?
Old Dec 24, 2009 | 09:36 PM
Your sway bar links are different than them.
You will need to jack the entire front end up and drop the exhaust to get to the o2 sensor.
You will also need a o2 sensor socket.
Old Dec 24, 2009 | 09:40 PM
gordon368's Avatar
is there a specific name for this jack that I need, can I get it from sears? Will I need this same type of car jack for the sway bar links? Thanks so many times over tech.
Old Dec 24, 2009 | 10:01 PM
It is just called a floor jack.
It would benice for you to get jackstands as well. This way after it is jacked up you can put the stands under there to make sure the car stays put.
Old Dec 25, 2009 | 01:15 PM
gordon368's Avatar
will something like this do the job,
http://cgi.ebay.com/ebaymotors/1-5-T...motiveQ5fTools
and the o2 socket, I typed it on ebay and only one kind came up like this one:
http://cgi.ebay.com/ebaymotors/o2-Se...item2557e0a050
Old Dec 25, 2009 | 06:02 PM
Yes that jack and jackstands will work perfect.
For the O2 socket try to find one like this.
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
Old Dec 26, 2009 | 12:30 PM
gordon368's Avatar
and is the oxygen sensor I need?
http://cgi.ebay.com/ebaymotors/OXYGE...item3a5542dcf6
Old Dec 26, 2009 | 07:12 PM
I don't think so unless they are totally screwing up the info.
They do not specify if it is a front or rear. Also they have the motor type listing the S40 motor.
Old Dec 27, 2009 | 11:33 PM
gordon368's Avatar
Im getting popping noises in the front also, as well under my center dash I get a snapping plastic noise, any idea of what this could be?
Old Dec 27, 2009 | 11:39 PM
I would check the front sway bar links as well.
I would fix those noises first and see from there.
Old Dec 28, 2009 | 12:11 AM
gordon368's Avatar
What do you think of this jack stand compared to the other one? I rather get it all from one site or company,
http://www.sears.com/shc/s/p_10153_1...ds+and+creeper
I didnt realize it but sears offers o2 sensors as well:
http://auto.sears.com/Volvo-S80-BOSC...splayItem=true
Think thats a fair price for everything including the socket you showed me?
Old Dec 28, 2009 | 08:18 PM
The O2 sensor is not that bad on price.
Not sure how much I would trust the jack though.
It seems a little small compared to the other one.
Aarondawg
May 25, 2010 08:42 PM
jonb007
Jan 5, 2010 01:24 AM
djechternach
Jun 15, 2009 07:44 AM
grand94jeep
Jan 6, 2007 05:05 PM
ludeless
Jun 13, 2006 08:15 PM
