Is it possible to clean a dash dimmer switch for a '95 850?
Old Jun 13, 2013 | 01:12 AM
Mumblix_Grumph's Avatar
Default Is it possible to clean a dash dimmer switch for a '95 850?
Hi, my dash light dimmer slider is going out. It only works in one spot about 3/4 full brightness. Is there any way to "clean" the contacts like you could with old radio pots? Could I spray in brake cleaner fluid and flush the crud out or just replace it?
Old Jun 13, 2013 | 02:18 AM
scutyde's Avatar
You can dissassemble the switch and try to clean it...although I wouldn't take brake cleaner as it is a very agressive stuff.
Take out the tail foglight switch first than the dimmer.
I would try WD 40 and afltewards contact spray. However I think it's better to just replace it...For the amount you are going to spend on a good used one I think it ain't worth the trouble
Cheers
Cristian
capulet_x
Jul 25, 2014 03:59 PM
ParkCity850
Nov 28, 2012 02:12 PM
rspi
Mar 31, 2012 09:29 PM
audis2vato
Jun 1, 2010 11:57 PM
montysano
Jul 15, 2007 08:52 PM
