Possible Replacement for PB Blaster...
Old Aug 20, 2006 | 11:06 PM
robert213's Avatar
Default Possible Replacement for PB Blaster...
I just had an old fence line removed this weekend. Actually, I had the old broken down fence replaced with a new fence.
In the process, several end-and-brace posts had to be dug out and removed. These end-and-brace posts were made of old rusty angle-iron. There were several rusty old bolts and nuts.
I hired a seasoned veteran fence guy. He has been building fences for over 41 years. He pulled out this blue spray can and sprayed the rusty bolts. He waited 1 or 2 minutes and he was able to loosen the bolts.
I read the info on the can...
Blue label with white lettering:
ChemSearch - Yield
http://www.chemsearch.com/productDet...ld%C2%AE%0D%0A
Loosens parts, protects them from rust and lubricates them for reuse
Yield® penetrates rusted and corroded surfaces without damaging vital parts or increasing expensive labor. In addition, it leaves parts protected and lubricated with a thin, but long-lasting, molybdenum disulfide film so they can be used again. Works immediately to penetrate rust, built-up grease, sludge, even electrical corrosion. Penetrates deeply, so it works even on countersunk bolts. Saves money because it protects parts from breakage when they are being removed. Prevents further rust and seizure of parts.
APPLICATIONS: Recommended for use on nuts and bolts, battery terminals, speedometer cables, brake cables, rusted rims, mufflers, commutators, starters, rusty arbors, carburetor jets, tail pipes, jammed locks, shackles, broken taps, gauges, pipes and aluminum heads
Do you have questions about a Chemsearch product or service? Would you like for a representative in your area to visit you? Let us know.
» Call TOLL-FREE 1-800-527-9921
Our Customer Assistance Center is available Monday through Friday from 8:00 AM until 5:00 PM Central Time.
» Write
Mail correspondence to Chemsearch Marketing 3N, 2727 Chemsearch Blvd., Irving, TX 75062
» FAX
In the US, fax to 972-438-0634.
It's easy to order from Chemsearch
You may place orders with Chemsearch through the sales representative who calls on you or you may call the Chemsearch Customer Assistance Center to help you.
Call toll-free 1-800-527-9921 Monday through Friday from 8:00 AM until 5:00 PM Central Time.
PinnacleWax
Nov 19, 2014 02:26 PM
xckidd
Apr 15, 2011 10:21 PM
spankey
Dec 16, 2010 09:51 PM
pvolvoman
Dec 15, 2006 09:23 AM
red pocket rocket
Sep 29, 2004 02:54 PM
