power seats
Old May 30, 2006 | 01:42 AM
Riculus's Avatar
Default power seats
My power seats not reclining. Is there an easy fix or I need to replace the entire seat electrical
Thanks
1995 850 GLT
167k and counting............
Old May 30, 2006 | 03:08 PM
robert213's Avatar
Default RE: power seats
Not sure. Do you hear the electric motor running? Most likely, something mechanical -- like cable -- has broken. May need an uphostery shop to help you gain access to problem area.
Old May 30, 2006 | 11:07 PM
The Cable most likey is stretched.
Common on these cars. If you hear the motor it is the Cable.
If you open the Seat and Heat the Metal on the end of the cable and slide the plastic in more that will fix it for now.
If you need to know how to Access the motor let me know and I will post it.
Old May 31, 2006 | 01:51 AM
Riculus's Avatar
yes the motor work. how can I get in to fix it
thanks
Old May 31, 2006 | 08:45 PM
If you feel at the bottom where the top section meets the bottom you will feel metal rings. They are called Hogrings. You will need to Cut them. Then start rolling the Leather up easy.You will find more as you go along. You will have to cut about 15 to 20 of them to get the leather High enough to get to the motor.
They will run up the Seat in the front and from side to side where you see the Seams.
You will have to buy new Hogrings and Pliers to install them.
The motor can be seen from the Back of the Seat when the Leather is up.
You will also have to unhook the Sides. The leather folds around and hooks onto a plastic cover.
TONY12340
Apr 15, 2015 05:47 AM
EastCoastVO
Feb 12, 2015 07:18 PM
olgol
Jun 9, 2010 12:58 PM
olgol
Jun 9, 2010 11:40 AM
tomservo
Interior
May 1, 2008 05:31 PM
