Problem with Brake Lights
Old Apr 8, 2008 | 03:05 AM
Volvofan916's Avatar
Default Problem with Brake Lights
Hello, I just bought a 1997 850 T-5 sedan. I'm having some trouble with the brake lights, neither side works. I tried replacing the fuse and changing the bulbs, but they still won't work.
Any suggestions?
Thank you,
Sean
Old Apr 8, 2008 | 09:42 AM
JPN's Avatar
JPN
Default RE: Problem with Brake Lights
I would suspect the stop lamp switch, which seems adjustable according to the service manual. Follow the brake pedal and look for components that have electrical wirings attached. It may only need adjusting or the electrical connector is loose.
JPN
Old Apr 8, 2008 | 03:15 PM
Very nice, thank you. I'll give that a try when I get home, hopefully this is a simple fix.
Old Apr 8, 2008 | 07:42 PM
robrike's Avatar
You might also want to get one of those wire bulb socket cleaning tools and really ream the bulb holders out and get a nice shine on them. I had the same problem including the center light and replaced the brake pedal switch and even resoldered the bulb failure box in the trunk and had nothing. I check the votage out of the wires and had power up to the contacts in the bulb holder. Scrubbed them crazy and voila, lights again. No idea how all three corroded at the same time but it is a tricky system and connection cleaness is a neccesity on these cars.
Fire me a PM if you have questions.
Rob
Old Apr 8, 2008 | 10:04 PM
JPN's Avatar
JPN
ORIGINAL: robrike
Rob
+1.
Good to see you Rob, been wondering about you.
JPN
Old Sep 4, 2011 | 04:04 PM
Alex Roa's Avatar
I'm having the same issue - did you have any resolution to this!? Much appreciated!
Old Sep 4, 2011 | 08:12 PM
Did you try the switch? Turn the lights on different settings and see if they work in either selection. Off/parking/driving. I had a problem with a 960, switch was coming apart on the back side. Took it out and super glued it back together.
aznyaz
Jan 9, 2015 02:38 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
Scott V
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
