Psycho turn signal
Old Aug 13, 2009 | 07:19 PM
TheTrainwreck's Avatar
Default Psycho turn signal
What would cause my left rear turn signal to keep cutting out. It just started today. It works then it doesn't, totally random. I'll put it on, get the fast clicks, then 2 sec later it works fine. WTF!!???
Old Aug 13, 2009 | 07:27 PM
gilber33's Avatar
The fast click usually means you have a bulb going out.
Old Aug 13, 2009 | 07:35 PM
I thought bulbs go when they go? The way it happens every once in a while leads me to believe its electrical.
Old Aug 13, 2009 | 07:37 PM
gilber33's Avatar
flasher unit is incorporated into the system and is used to break and then reconnect the turn signal lighting circuit; this is what creates the blinking action. This flasher depends on resistance in the lighting system (front and rear bulbs) to operate correctly. If a bulb fails, the resistance in the system changes causing the flasher to blink quickly.
So you could have a bulb going out, or maybe it's a fuse or relay.
Old Aug 13, 2009 | 07:38 PM
Ok ill change the bulb tomorrow.
Old Aug 13, 2009 | 08:08 PM
gilber33's Avatar
Put on your turn signal, get out of the car and walk around and check to see if it's the bulb.
Old Aug 13, 2009 | 08:21 PM
850tony's Avatar
could be a bad connection also. or a bad flasher...
Old Aug 13, 2009 | 08:22 PM
I did that. It just decides to either work or not. I'm gonna replace the fuse and bulb just to be safe. Should I replace all the fuses?
Old Aug 13, 2009 | 08:24 PM
850tony's Avatar
no lol. a fuse is GOOD or BAD. is the system is working the fuse is just fine (kinda like a link in a chain.)
Old Aug 13, 2009 | 08:27 PM
gotcha. thnx tony
suckonthiscaravan
Dec 5, 2018 03:19 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
mdp61377
Jun 23, 2005 02:13 PM
lounytoon
Nov 23, 2004 03:23 PM
