question about a/c and a/t on a 850 turbo
Old Aug 11, 2005 | 01:49 AM
afbere's Avatar
Default question about a/c and a/t on a 850 turbo
[X(]I have a 95 volvo 850 turbo and i have two questions to the tech.
On my ac?i have notice the my ac compressor engage as soon the i move the key to the 2nd position and the ac stay on at all
times and i have check all wiring to make sure there are no bypass on any area so any idea why ?
i have also check to make sure that the control is not on the defrost setting.
On my transmision my car has already 105k miles and i have no record if the previous owner replace the fluid and i have notice
that the color is kind of brown so did you think that i should replace the fluid?
thank you.
Old Aug 11, 2005 | 04:29 PM
info2x's Avatar
Default RE: question about a/c and a/t on a 850 turbo
Not sure about your AC problem, maybe your clutch has seized.
Flush your transmission I believe the recommended interval is every 70K.
Old Aug 11, 2005 | 09:39 PM
The clutch might be melted or the gap is to close to the pulley.
Also there should not be a request for the A/C all the time.You can disconnect the low pressure switch and see if the compressor kicks off.
As far as the trans I would flush it and get clean fluid in there,
Old Aug 12, 2005 | 01:04 AM
afbere's Avatar
thank you for your response i will replace the fluid asap and try to remove the plug from the low pressure to see if the
compressor goes off.
thank you.
Keith Tobberman
Sep 30, 2011 10:36 AM
lxzero
Nov 10, 2009 09:16 PM
96850urbo
Jan 23, 2009 01:00 PM
Svtfiveoh
Aug 29, 2008 08:58 PM
my850turbo
Dec 12, 2005 01:23 AM
