Radiator cooling fan? How to troubleshoot?
Old Aug 1, 2008 | 05:34 PM
wheelsup's Avatar
Default Radiator cooling fan? How to troubleshoot?
Pulled in to the garage today, A/C was clicking on and off, thought it was low on 134a. I popped the hood and started adding some and noticed the cooling fan wasn't on, and the compressor just went silent. I hopped in the car, noticed hot air coming out of the vents, and the engine temp pegged at the top.
I know there's a way to check the relay to see if it's that or the fan, what's the trouble shooting on this thing? I searched but couldn't find the answer.
The T-stat was replace about 6 months ago, and there's new coolant in the system (<2 months old).
Old Aug 1, 2008 | 06:28 PM
Default RE: Radiator cooling fan? How to troubleshoot?
Can you spin the fan by hand easy? Also take a test light and ground the one side then probe the small wires in the center of the relay and see if the fan comes on.
Old Aug 1, 2008 | 09:04 PM
wheelsup's Avatar
OK let the car sit, started it up, a/c on, fan comes on just fine. Go around the block, park in the garage, and fan is on. Stop the car, turn it back on, a/c on, fan not on, compressor starts clicking on and off again.
I go through this a few times, drive to Lowes in my other car and make my own jumper.
Old Aug 1, 2008 | 09:11 PM
wheelsup's Avatar
WTF IT WON'T LET ME POST MY MESSAGES???
Old Aug 1, 2008 | 09:39 PM
wheelsup's Avatar
This is too funny, it lets me post messages like this but not actual messages with useful text in them.
Old Aug 1, 2008 | 09:48 PM
wheelsup's Avatar
Link to the full post...
http://www.matthewsvolvosite.com/cha...ic.php?t=16008
Old Aug 2, 2008 | 06:24 AM
Maybe the relay is bad.
Old Aug 2, 2008 | 01:29 PM
wheelsup's Avatar
That's what I was thinking, but once when I tried to jump it, the fan didn't come on. But did when I unplugged and replugged the ground back in (with it still jumped).
If that hadn't of happened I would've thought "relay" right there. I suppose it also could be that the jumper didn't have good contact with the battery, and just happened to come on when I giggled the ground wire.
I put a new relay in, I hear they are a common failure anyway, so hopefully this fixes the issue. If not at least it's fixed for the future, and will narrow down the issue later.
Hopefully it's fixed, seeing the temp pegged and coolant boiling scared the crap outta me!
Old Aug 2, 2008 | 09:02 PM
Hope all is well.
that4wdwagon
Dec 8, 2014 05:23 PM
cortez.victor97
Jul 24, 2012 06:52 PM
moros323
Jul 26, 2008 09:00 AM
elouadj
Jun 25, 2008 07:00 PM
jamyers
Jan 7, 2008 02:27 PM
