radiator replacement
Old Sep 12, 2010 | 04:06 PM
tater's Avatar
Default radiator replacement
I'm trying to change my radiator due to it leaking. Well is there a trick to getting the bolts that hold the radiator in off? i finally got the drivers side but can't get the pass side one more then half way
Old Sep 12, 2010 | 04:14 PM
ibified's Avatar
They should come straight out. That's kinda odd. Are you talking about the ones on the sides that you have to do from underneat the car? Check to see that the nut that's welded on the top side didnt break loose. if that happened, you'll have to hold a box wrench on the nut while you spin the bolt from underneath.
Old Sep 12, 2010 | 04:16 PM
tater's Avatar
the piece the bolts go into broke off and just spin. i had to use vice grips on the driver side but i cant get them into the pass side
Old Sep 12, 2010 | 04:21 PM
ibified's Avatar
if you cant get something in there, your only other option might be cutting the mount off. either that, or get yourself some more space by taking off the intake manifold.
mikeawd850
Nov 30, 2012 02:26 AM
jcmartin
Oct 6, 2008 08:48 AM
spioana007
Dec 13, 2007 06:13 PM
Pepper
Nov 9, 2007 06:37 PM
mikkowus
Jul 25, 2007 04:56 PM
