Radio Will Not Power On
Old Mar 25, 2007 | 11:10 AM
JimKW's Avatar
Default Radio Will Not Power On
I pulled the head unit out of the 97 R to replace one or two the bulbs again. When I put it back in, it would not get power. I put the spare unit I have from the old 94 850 and it gets power, so I know the problem is within the unit. I took it back apart and don't see any fuses or anything inside the unit. Any suggestions?
Never mind. I got it. It was the band that slips in behind the Bass, Treble and Fader slide switches.
Old Mar 25, 2007 | 11:54 AM
JPN's Avatar
JPN
Default RE: Radio Will Not Power On
Hi Jim,
Since I don't have the car handy, I can only guess.
Check the connector pins on the radio for power & ground to make sure they are not bent/damaged. Also, the problem may be in the power/volume ****. It may have an internal fuse (the old tube-type) on the circuit board, or on the back panel but I'm not sure. I assume the problem is minor, as it was working before you took it off, right?
Tech seems to be unable to come here for a while, so we'll have to figure out. I think Axel in Argentina could give you better suggestions than I could, as Axel's good at electrical/electronic systems.
Please update us.
JPN
[IMG]local://upfiles/6892/E59E75D07C3A4CCBAEFA90EC5049A542.jpg[/IMG]
Old Mar 25, 2007 | 12:07 PM
JPN's Avatar
JPN
Jim, I forgot to mention the universal cure for electronics.
Hit it like a man[8D].
Just kidding, hit it with a moderate force to see if it comes back to life.
Those SC-whatevers are made in Japan. I don't know who makes them, but probably not a top-brand.
Many Japanese products' qualitywent down recently due to exporting factories overseas and hiring locals with poor conditions. The difference between the rich & poor is widening rapidly[8D].
JPN
richardgrant
Apr 28, 2015 08:22 PM
cbgav
Sep 10, 2007 05:25 PM
Patdon10
Jul 19, 2007 01:06 PM
