Radio wiring blows fuses HELP!
Ok, so I picked up a volvo 850 just to get back and forth to work, great car good gas mileage but there's a problem. The owner before me decided to do a little DIY stereo installation. Well today i think i drove over a small bump and immediately the stereo shut off. I pulled over checked the fuse and saw that it was blown and went to replace it, it immediately blew. Then i figured i would disconnect the stereo to make sure it wasn't the stereo. No dice, the stereo was disconnected and the fuse immediately blew again. I took the stereo out and inspected the wiring harness, it's a really horrible wiring job, electrical tape and splices everywhere, I went over everything and didn't see anything grounding, plus there's nothing else for it to ground to considering everything around the wiring is plastic. I checked everything, went over all the connections with liquid electrical tape, and it's still blowing the fuses. Does anyone have any ideas as to what i should check, or is there a way i can just draw the power from the cigarette lighter to get by, because i have an hour commute and really don't want to have silence.
Thanks in advance !!
Ryan
Ryan
If that is fuse 15? Then you have other issues.
I would disconnect all the wiring from the radio and tape off everything.
Replace the fuse and see what happens.
That fuse #15 is
15 - 10 Amp (1996)
Audio System, Courtesy Lights, Door Open Light, Trunk Light,
Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
Could be a short in any of those things above.
That fuse #15 is
15 - 10 Amp (1996)
well all those things you mentioned aren't affected. the fuse is number 7 i believe and the only thing it controls is the radio, so i guess i'm lucky in that regard. everything else is working fine, just the radio, and i can't for the life of me find where it's shorting out, visibly everything looks ok, is there any easy way to find out where it could possibly be coming from, i'm betting there isn't
volvamos
12-23-2014 09:56 PM
