Rapid Fuel Evaporation
Old Jul 1, 2007 | 07:36 PM
RedTurbo850's Avatar
Default Rapid Fuel Evaporation
Hey,
I'm getting some massive fuel evaporation problems. I lost about 1-2 gallons over night. I had 6 gallons last night, and today, I just turned on my car and I got about 3-4 gallons...
I checked my fuel pump and the assembly on top is wet but there isn't much accumulation.
That being said, the place where the wires come out is jelly.
My car also smells like gasoline sometimes when it's hot or even sometimes while i'm driving.
I mentioneda couple months ago that when I fill up gas to the max, I had some gas hit the ground and it was almost as if it were overflowing...It there any way to check this for a leak up here?
Recently, I put in some injector cleaner because I read that I could have a wacky fuel reading unit. After this, when I fill up, I can no longer "auto fill". Once I go all the way, the pump will click and it'll stop. I have to manually do it...
Is it possible to figure out myself or do some type of preliminary work, or should I just take it to the shop?
Old Jul 2, 2007 | 07:22 AM
axelm's Avatar
Default RE: Rapid Fuel Evaporation
If it were my car I'd make sure my fire extinguisher is working andI wouldn'ttransport anyone in the back seat untilI had the problem fixed.
Old Jul 2, 2007 | 05:52 PM
The gas runs off the top of the tank very easily.
is your hose in good condition.
Old Jul 2, 2007 | 11:12 PM
ORIGINAL: tech
Are there hoses outside of the ones that go to the fuel pump?
Because I did feel the top of the tank, and there was wet debris that smelled of gasoline..
If I remember correctly, there are 3 hoses...
Would I need to drop the tank to check?
Old Jul 3, 2007 | 05:28 PM
One you can see through the 2 access hole and from under the car.
The others you will have to drop the tank to see.
Old Jul 3, 2007 | 06:29 PM
Pics.
Someone on Volvo Speed had a problem similar to mine, and they determined it was the red hose in this pic.
But here are my pics.
Old Jul 3, 2007 | 07:42 PM
Looks like the same thing on yours.
The big one to the right with the really rusty clamp is the hose that usually goes bad.
Old Jul 3, 2007 | 08:42 PM
Alright thanks for the hlep.
This for reference was the original guy's...Seems like his problem was a lot more serious..
Old Jul 3, 2007 | 09:18 PM
parkerjensen's Avatar
i had the same issue on my 97 t-5 wagon, it was covered under a factory recall about 9 to 12 months ago.
Old Jul 3, 2007 | 09:40 PM
The recall only covers the Heat sheild mountings on the fuel tank.
If they aren't cracked they install rubber mounts and reinstall the heatsheild and done.
Old Jul 4, 2007 | 01:13 PM
m1964's Avatar
ORIGINAL: tech
Would they advise the customer if they seethat repair is needed or they don't care and just do the recall?
Old Jul 4, 2007 | 05:55 PM
ORIGINAL: m1964
ORIGINAL: tech
Rephrase the question?
Old Jul 5, 2007 | 04:16 AM
JPN's Avatar
JPN
If you have the recall done at a dealer, they probably would notice the other evaporation problem. Or, you can tell them to check before they do the recall to make sure to check for other hazards around the fuel tank.
Hey Jimmy,
I finally got DSL going at my new apartment. Trying to catch up here. I believe you'll be ok since you've got an advice from Tech. Note, that gasoline is extremely volatile and even if there was a leak, liquid gasoline can transform into gaseous form very rapidly and there may not be a puddle. Vapourised gasoline is easily ignited so be careful.
JPN
Old Jul 5, 2007 | 09:33 AM
axelm's Avatar
ORIGINAL: JPN
JPN
I totally agree on this. I worked for a major gasoline pump manufacturer for 8 years and I've heard many stories (which I can't repeat due to NDA).
Be safe and make sure your fire extinguisher pressure is ok.
Regards
Axel
Old Jul 5, 2007 | 11:30 PM
ORIGINAL: JPN
Hey Jimmy,
JPN
Yeah. It's the Vent hose that seems to be bad.
Called the dealer today and it's 15.76. I'll pick it up tomorrow and have my mechanic install it since I'm not going to drop my own tank...
smithnr
Apr 8, 2013 04:56 PM
Paudman
Dec 19, 2007 05:50 PM
chaniewski
Nov 13, 2007 05:50 PM
DPNolen
Apr 27, 2006 11:42 PM
edahlgren
Oct 7, 2005 09:53 PM
