Re-installing factory cargo pet barrier net that unreels?
Old Feb 14, 2011 | 10:21 AM
bond007's Avatar
Default Re-installing factory cargo pet barrier net that unreels?
When I got my '97 850 wagon, it came with a black net sitting in the cargo area. I looked in the owners manual, and I learned this past weekend that it actually unreels from the back seat and is kept in place by two clips to the sides of the roof headliner. Somehow the P.O. took it out and now it's just sitting in the cargo area. The holding clips are still in the headliner, but I have no clue as to how to put the roller/net assembly back into the desginated space on the back seat. The dealer where I got the car from has no clue either. Any help appreciated.
Thanks
Old Feb 14, 2011 | 12:15 PM
vjaneczko's Avatar
The back-side of the rear seat has thin spring-loaded flaps that fold down. The net would roll into those spaces. Is that what you're talking about?
Old Feb 14, 2011 | 04:31 PM
boxpin's Avatar
I just went and looked at my car. As far as I can tell your going to have to take the plastic trim off (top and end caps, the whole thing) and possibly unzip the carpet.
Attached Thumbnails Re-installing factory cargo pet barrier net that unreels?-img_0593%5B1%5D.jpg   Re-installing factory cargo pet barrier net that unreels?-img_0595%5B1%5D.jpg
Old Feb 14, 2011 | 07:04 PM
bond007's Avatar
Thanks, I already learned about the flip covers, but the problem now is how to get the roller/net assembly into those spaces( the previous owner took the whole thing out of the back seat covers and now the 2 pieces are just sitting in the cargo floor), it doesn't fit just by opening the flaps, so I'm guessing it's way more involved than that.
Thanks
Old Feb 14, 2011 | 07:05 PM
bond007's Avatar
Thanks for the photos, they help me orient things better now.
Old Apr 5, 2011 | 10:51 AM
bond007's Avatar
Still unable to put the net back after all this time. I'm having trouble removing the seats "end-caps" as they're held in place by some sort of push-in? pins. Are there any instructions/thread/photos on how to install this thing? Dealer wants an arm and a leg to install it back.
Thanks
Old Nov 4, 2011 | 06:06 PM
randyellin's Avatar
I just did this on my friend's 2000 V70. Will post my procedure as soon as I can.
Old Nov 6, 2011 | 10:29 AM
Most of the push-in clips on Volvo's just pull out with some thin pointed object. The net has a real, I really can't imagine how they tore that thing out.
Old May 30, 2012 | 03:15 PM
catherooney's Avatar
Thanks
did you ever manage to get your nets fitted? I am having similar trouble. Also I have some attachments that are supposed to let you use it when the seats are folded down but I have no idea how they attach to the passenger handles. Has anyone got some fitted that they could take a photo of?
Old May 30, 2012 | 05:17 PM
There are 2 ring clips just aft of the back door pillars, one on each side. There are another set of the ring clips on the forward edge rear seat handles (against the lights). When the seats are folded down, the net attaches to the ring clips on the handles, when the seats are upright, the net attaches to the rear ring clips.
Old Apr 19, 2016 | 08:13 PM
TANKWGN's Avatar
Default Removing the cargo nets and reinstalling them
So I wanted to add the cargo nets to my '94 850 wagon and today I went to my local LKQ yard (highly recommend they didn't even charge me for nets!). So after doing research I had a pretty good idea on how to remove the nets. It requires a little destruction but it isn't that hard.
The nets are compatible with '94-97 850's and '98-00 V70/XC
Step 1: find car with nets
Step 2: fold seat back and remove screws on inner side of seats(2)
Step 3: on the side closer to the doors find the little circular shaped plugs near the seatbelt
Step 4 (the destructive step): take a drill or screw driver and pull out the plugs
Step 5: move cover and take flathead screwdriver and pry off metal washer
Step 6: push rod inwards and remove nets
Step 7: remove hooks in ceiling
Installing
Step 1: remove two screws holding inner cover and put aside
Step 2: make sure the nets are fully rolled up and slide in
Step 3: open flip covers and slide rod into hole on outer side of seat
Step 4: rotate end plate a few times to build up tension
Step 5: rotate end plate a little more until it moves further into compartment and let go to make sure it doesn't unroll
Step 6: reattach end plates and you are done!
I will take pictures of the steps and share them when I can return to a yard
Heath7
1998-2000 model year XC70
Apr 29, 2013 10:53 AM
Nickshu
Feb 25, 2013 08:50 AM
bostonman
2001-2013 model year XC70
Feb 4, 2013 05:57 PM
sundance
Aug 12, 2012 08:27 AM
sundance
Oct 2, 2009 06:32 PM
