Rear load leveling
you can google Nivomat for an explanation. They are easy to spot - standard shocks are straight metal tubes - Nivomats are fatter. I wouldn't bother looking to add them in - but considering your car is 20 years old, you can consider replacing the rear springs. You can check out IPD USA for their rear "overload springs" for $129 a pair (great price) or replace your old springs with new OEM quality stock springs. YOu should also consider HD shocks
It is neat, in that the shocks pump themselves up using suspension travel, so it's all self-contained. I've never had one so equipped. I suppose the shocks are so expensive that nobody converts a car to Nivomat, but that would be cool. The old fashioned adjustable solution in the USA at least was air shocks. You could adjust them, but it takes a little time. I don't know if anybody makes an air adjustable shock that would fit it.
va740twagon
11-07-2018 09:43 AM
jollygoodgold
03-22-2013 08:34 PM
