1997 850R cranking but wont start need help please
Old May 3, 2018 | 05:18 PM
anty's Avatar
Default 1997 850R cranking but wont start need help please
Hi members
Ineed some help please ive got a 850r 5sp and the other day irode into quite alot of water after it had rained and the car was spluttering and missing for about 6 miles then it started to run smoothly again and drove for about 2miles then it died on me .Had to tow it home the next day i cleaned and dried all the wire plug connectors took the distributor cap off and dried that aswell .nothing was really wet but sprayed wurth electrical cleaner on every connection and distributor ,but it would not start checked for spark and no spark at all looked on youtube and checked the crank sensor which is fine but camshaft sensor pin 3 has no 12 v on it .now is it controlled by the ecu or can i hot wire it from battery? will it damage my ecu or not ,any body please help if you can thanks anthony
Old May 8, 2018 | 07:30 AM
anty's Avatar
What is there no one that can help me please cause i see 97 views but no replies
Old May 8, 2018 | 09:01 PM
did you check the fuel injector relay?
Old May 9, 2018 | 04:04 PM
anty's Avatar
hi yes fuel relay working fine but no spark
Old May 19, 2018 | 03:50 PM
italcarnut's Avatar
Did you check for codes? I had a similar problem and Cam position sensor went on me all of a sudden. Replaced it and she fired right up.
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
Erica Alpuerto
Apr 3, 2012 11:50 AM
thehacker44
Mar 9, 2012 08:23 PM
Riculus
Nov 7, 2009 12:01 PM
joker834
Nov 15, 2006 10:15 PM
