Removing Glove Box
Old Aug 15, 2008 | 06:57 AM
raybun's Avatar
Default Removing Glove Box
How do I remove the glove box? I need to remove it to see if the car is fitted with a keyless entry sensor. I also need to do this to see what can be done about a broken glove compartment door hinge. I am leery of blundering about so close to the air bag without knowing what I am doing.
Thanks
Ray
Old Aug 15, 2008 | 06:52 PM
Default RE: Removing Glove Box
Remove the screws in the insert. Then there is little slots you stick a small screwdriver in and pull the arms out. Then the insert will come out.
Old Aug 16, 2008 | 11:05 AM
Ozark Lee's Avatar
+1
Don't worry about the airbag, the sticker on the knee bolster is just warning you that you are getting close.
...Lee
tech
Feb 2, 2014 11:52 PM
toadles
Nov 8, 2008 08:22 AM
robert213
Apr 30, 2006 06:33 PM
tech
Feb 24, 2005 07:51 PM
ahn2u
Feb 24, 2005 07:44 PM
