Repair order advice: preventative engine or needed suspension?
My 97 855R needs new spring seats, tie rod, control arm and likely struts. I also want to do some preventative engine stuff; the common tune up and PCV kits, even though I don't have any codes, engine issues or smoke in the dipstick.
I'd like to tackle one issue at a time, as I'm new to this. Generally, should the engine stuff take precedence over the suspension issues? If it's a question of preference, which would you do first?
on
1 Post
Just my own opinion, but I believe you should tackle the suspension / steering related issues first.
Safety first is basically the thing.
Non urgent engine maintenance can take a back seat till you get the important safety matters seen to. (Your post implies that the engine has no issues currently)
Suspension is what I am aching to do, but figured the engine should come first for reliability. But you're right, if there isn't an apparent reason to be concerned there, but there is elsewhere, I should hit the elsewhere first. Thanks.
Well, it depends on what is pending the most damage. A clogged up PCV system can blow a RMS, that will set you back over $900. It is also an in-expensive thing to deal with. Also a broken old spark plug can break and chip a valve. Where as a bad shock can be lived with as long as you are not racing around town.
Brakes are safety, struts can be driven safely no matter how bad they are.
mexicanfooddude
07-13-2015 05:32 AM
