Replaced MAF, still idling rough/stalling at stop
Old 01-04-2015 | 01:40 PM
arisquared's Avatar
Default Replaced MAF, still idling rough/stalling at stop
Hi folks,
After poring over this forum when my '96 850 would start and die out, i pulled and replaced my MAF (easy peasy). However, I'm still running a little rough--she stalls out when I'm at a stop sign or a red light. The problem is intermittent but I want to make sure I did the job right.
I have a fuel pump relay on order from eBay because I hear they frequently go bad on cars that old.
Any suggestions?
Old 01-04-2015 | 05:27 PM
Symptoms of the fuel pump relay would also include low engine power/car won't rev (ie the relay doesn't allow enough current to the pump to create full pressure but may have enough current to start or idle rough) or the behavior changes as the relay warms up. You didn't mention and engine codes so my next question is when did you last do the plugs/wires/rotor&cap? I'd be suspicious of vacuum leaks for starters if the car seems to have reasonable power.
Old 01-05-2015 | 08:02 AM
arisquared's Avatar
I have an OBDII reader on order and as soon as I get it I'll pull the codes. I just got the car in August, and naturally things start acting up as soon as it starts getting cold here in MN.
I'll get back to you when I can pull those codes. I don't know when the plugs and wires were done, though.
Thanks!
Old 01-06-2015 | 10:12 PM
You can also swing by most auto parts stores and have the codes read for free too.
Brandy1
2001-2013 model year V70
11-24-2012 06:38 PM
pack_85
06-16-2010 12:02 PM
Chart
11-15-2008 12:26 PM
ariston
06-29-2008 12:24 PM
troche
05-03-2006 09:12 PM
Quick Reply: Replaced MAF, still idling rough/stalling at stop
