Replacing Turn Signal Assembly
It is pretty easy to replace.
The covers might break when taking them off.
There is 2 T-15 screws holding the upper cover to the lower cover. They are right behind the steering wheel up in there deep.
There is 2 or 3 T-25 screws holding the lower cover to the column. Then once the covers are off there is 2 t-25 screws holding the arm to the column.
Replaced mine a few weeks ago. Part is kind of expensive (~$125)if you can't find one in a junk yard.
Search here on the forum and you will find a couple of HOW-TO's. I think it was about a 20 minute project. Took longer to locate the Torx drivers necessary for the job.
Good Luck,
Kirk
Good Luck,
Kirk
